Old 03-05-2003, 04:32 PM   #1
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Tuckin' Rim
I am looking at the Vision 256 at visionwheel.com. If i wanted to get the 17x9.5 rim for the rear of my truck, would 5.25 backspacing be enough to tuck it and drag frame?
Jason
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 03-05-2003, 06:00 PM   #2
Slammed67
Progress = 0%
Slammed67's Avatar
That is the back spacing I have on my 18x9.5's and they tuck. Just don't get too wide of a tire. I think mine are 285/40/18's. If I had gone with any wider of a tire, I probably would of had to go with 5.5" b.s. Right now I've got more clearance on the inner part of the tire that the outer. But you want to keep them as far out as possible to look good. Of course I'm not dragging frame (nor would I want to). But with it dropped on the c-notch, they fit just perfect.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 03-05-2003, 08:01 PM   #3
crazy longhorn
Fabricate till you "puke"
Layin the rails is cool when you are parked........but please tell us you dont plan to make sparks with that pretty truck!
crazy longhorn is offline   Reply With Quote
Old 03-05-2003, 09:10 PM   #4
RACING29
DRAG IT!!!
1967 Chevy truck, R1 racing seats, 4 point racing harness, 4/6 drop, primered blue, soon to be shaved, 350- 060. over, flat top pistons, Eagle rods, Edelbrock Aluminum heads, 1.5 Scorpion roller rockers, Lunati 515" cam, mallory ignition, Holley 750 double pumper carb, Built 350 turbo trans, 2500-2800 boss hog stall, 20 gallon aluminum fuel cell!!!
RACING29 is offline   Reply With Quote
Old 03-06-2003, 01:04 PM   #5
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Don't worry Longhorn, I am not planning on dragging it sitting or cruising i was just using that to let people I want to tuck the rims. Thanks Slammed for the info
Jason
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
