Old 03-06-2003, 08:48 PM   #1
canso
700r4 install driveshaft ?
I have installed a 700r4. I have a driveshaft off of a 83 Chev vehicle that is the correct lenghth. The newer drive shaft has larger caps on the u joints. Where the drive shaft connects to the tranny I have no problem. Where the drive shaft connects to the rearend, the caps are smaller on the diff yoke. I am told there is a standard cross over u joint for this. Instead of using a cross over u joint I would like to change the yoke on the front of the diff to one with the larger caps. I need to figure out what to get a yoke off of that will work. I am wondering if anyone has been through this. My diff is a 72 12bolt. Thanks
canso is offline   Reply With Quote
Old 03-06-2003, 08:51 PM   #2
Jwill41
Jwill41's Avatar
i would go with the "cross over" u-joint. There is nothing wrong with doing it that way and they are availiable at most parts stores.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 03-06-2003, 08:56 PM   #3
canso
If I can not find the right part, I will have to go with the crossover.
