Old 12-15-2010, 05:32 PM   #1
rhamlin
Front Drum Brakes
I have to replace the drums on my 68. I just cannot afford to convert to disc right now. Has anyone had experience removing the riveted center hub from the front assemblies then placing them in new drums ? Can I get some pointers ? Should I just find a machine shop ?
Rob Hamlin
rhamlin is offline   Reply With Quote
Old 12-15-2010, 05:52 PM   #2
cdowns
cdowns's Avatar
Re: Front Drum Brakes
you just buy replacement drums and they slip right on where the old ones went
Old 12-15-2010, 05:55 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Drill the head off the rivet,then lay the drum down and rap on it with a hammer.Don't hit the hub unless you use a piece of wood to protect it.There's no need to rivet the new drum to the hub.Don't forget to repack the wheel bearings.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-15-2010, 06:03 PM   #4
mr48chev
mr48chev's Avatar
Normally I've just taken and angle grinder and ground the heads of the rivets off or taken my air chisel and knocked the heads off. You will most likely grind the rest of the rivets down flush or knock them out but that shouldn't be hard then the new drums should just slip on.
Old 12-15-2010, 06:32 PM   #5
geezer#99
geezer#99's Avatar
New drums won't likely have a window in them for shoe adjustment. You'll need to make one in the backing plate.
brakes, drum, front, rivets
