Old 03-08-2003, 05:00 PM   #1
bigjimzlll
bigjimzlll's Avatar
so I went to the track today
Hi...went to the test and tune...I had serious fuel delivery problems..I think the stock behind the seat tank is hurting me, and my carter 750 would almost stall off the line..I couldnt run the N20, with the fuel problem, so heres my time slip
reaction----.738(test and tune)
60'(LOL)-----2.188
1/8 mph------79.79
1/8 time-----9.144
1/4mph-------101.34
ET-----------14.034
I knoww theres a lot more in it...I have a holley 750dp on its way and im getting a fuel cell
Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 03-08-2003, 05:43 PM   #2
383 Stroker
383 Stroker's Avatar
The MPH looks good. What kind of fuel pump are you running? What size ET Streets do you have?
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 03-08-2003, 06:58 PM   #3
bigjimzlll
bigjimzlll's Avatar
the et streets are11.5X28..I have a holley blue pump, but I kept sucking air in the line...I just got a rci fuel cell..im installing it now..the new holley will be here next week
Jim
Anderson,CA
Old 03-08-2003, 09:45 PM   #4
bigjimzlll
bigjimzlll's Avatar
man do I feel stupid....when I got to the track I adjusted the timing....then I forgot to put the vacuum advance hose back on...doh...no wonder my 60' times were so bad...oh well
Anderson,CA
Old 03-08-2003, 10:34 PM   #5
nate68
pm me next time you go to the track, especially if its one of the grudge nights. i wanna get my truck to be able to pass tech so i can go one of these days
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 03-08-2003, 10:34 PM   #6
nate68
Old 03-08-2003, 10:42 PM   #7
383 Stroker
How much timing do you run? I run 30 degree's total with the 150hp shot. I don't use vacuum advance.
Old 03-08-2003, 11:36 PM   #8
bigjimzlll
bigjimzlll's Avatar
im running 36-38 with out N20...I can go up to 40, without detonation. I have my curve set up for the vacuum advance..that might change.. 383 stroker whats your 60' times?
Anderson,CA
Old 03-08-2003, 11:37 PM   #9
bigjimzlll
bigjimzlll's Avatar
Nate..the track has 15 grudge(street legal) nights this year..this friday is the first one...
Anderson,CA
Old 03-08-2003, 11:43 PM   #10
383 Stroker
bigjimzlll, my best 60' without nitrous is 2.00. I had a 1.96 60' on the 7.99 pass with the 150hp shot. That was spinning on a old set of Hoosier Quicktime's 295/50-15. I'm going to get a set of 28x13.50-15 ET Streets before I go back to the track.
