Old 03-09-2003, 01:08 AM   #1
ScottH
ScottH's Avatar
Considering buying a 4x4, what to look for?
I have a 72 C20 and 69 C10, but considering buying a 71 K10. Can anyone tell me what to look for when buying a 4x4 (aside from the usual rust)?
Thanks.
ScottH is offline   Reply With Quote
Old 03-09-2003, 01:13 AM   #2
Blue_71
Bloo
Blue_71's Avatar
front driveshaft broke at either mounting end and front hubs are two i would defintly check
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 03-09-2003, 01:15 AM   #3
ScottH
ScottH's Avatar
Thanks for the info, how, or what, should I check the on hubs?
Old 03-09-2003, 01:22 AM   #4
Blue_71
Bloo
Blue_71's Avatar
how easily they engage, on mine they are both hard to turn and you have to engage the right one before you can the left... bad comparison, but on my grandpas f@rd, you can turn either one first and they are both smooth... on the driveshaft, a peice near my transfer case was broke and the driveshaft sit down on the x-member , it would still work though, but i didnt like it being broke
1989 Chevy K2500
Old 03-09-2003, 01:26 AM   #5
Hutch
Hutch's Avatar
Make sure it is in fact an original K Series truck.
Some of the earlier ones (67 68) had issues with frame cracks where the steering box mounts to the frame.
Not sure about 71's
These cracks are not easily seen due to the grease and dirt build-up in this area.
I like things as they came from the factory.
I would run all the numbers and make note of any modifications.
Have fun
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 03-09-2003, 02:38 AM   #6
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Check for smooth operation of the 4x4 shifter......my 90 K-5 Jimmy is hard to get into low range because someone got jerk happy and bent the linkage. I'd also drive it a little in 4 wheel drive to listen for excessive grinding or howling.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
