Old 12-29-2010, 12:03 PM   #1
1972CST
1972CST's Avatar
factory locker?
Is the "gov lock" locking diff the 12bolt axle similar to the eaton locking diff in the late 90's z71's (G80)?
1972CST is offline   Reply With Quote
Old 12-29-2010, 06:52 PM   #2
LONGHAIR
Re: factory locker?
Yup, but I wouldn't bother with the time and expense to install one. They are a known issue in all but the most mild conditions and driving styles....and if you drive like that, you don't need posi-traction anyway.
Just an FYI, they do not "lock" like a traditional "Detroit Locker". A "Gov-Lock" is just a clutch-type posi-traction with a mechanical governor that controls the pressure to the clutches. It is way too complicated, with tiny parts that cause catastrophic failures.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 12-29-2010, 07:38 PM   #3
Altec
Getcha Pull
Altec's Avatar
Re: factory locker?
They don't call them grenades for nothing!
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 12-29-2010, 08:35 PM   #4
Re: factory locker?
They are good for what they are designed for and used properly. I've never had a problem with one. They are a ball-ramp design that engages with wheel speed. If you pound the peddle hard before it's engaged you can hurt it. If you just get it to spin and wait for it to engage it'll get you out of a spot. It's not a hard core off road traction devise,like anything factory except the good old No-Spin which is a Detroit Locker. I compare it like this...if you put a limb in a chipper,then start it and go to rev it,it'll stall. If you have it running and revving,then put a limb in it turns it to chips. You just have to know how to use the equipment and use it that way. The Gov-loc isn't good for drag racing or rock climbing but is better than an open diff when extra traction is needed. The one in my suburban has kept me from getting out and locking the hubs more times than I can count.
Old 12-29-2010, 09:29 PM   #5
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: factory locker?
Good explanation Tim.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-30-2010, 11:50 AM   #6
snj8198
snj8198's Avatar
Re: factory locker?
It's pretty neat when they come apart!...... if you don't care about that housing.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 12-30-2010, 11:53 AM   #7
1972CST
1972CST's Avatar
Re: factory locker?
Wow, thanks for the insight. Could the no-spin be found in the 12 bolt or in the Dana products?
Old 12-30-2010, 01:13 PM   #8
Redcap
Re: factory locker?
They are known locally as the Gov-Bomb for good reason.
Redcap is offline   Reply With Quote
