03-10-2003, 01:37 PM | #1 |
Question About Windshield Trim???
I have a '72 but I have some good stainless windshield trim I pulled from a '70 GMC. Can I just buy the windshield gasket for a 1970 and use my '72 glass and the '70 trim?
Also, who sells the best fitting gasket? Thanx!! |
03-10-2003, 02:42 PM | #2 |
I don't know who has the best gasket, but you can put the 70 seal into your 72.
Jim |
03-10-2003, 09:38 PM | #3 |
Roadtrip!
trim
Make sure when you buy a new gasket you get one that is for the trim package. Some gaskets are not cut out for it.
03-10-2003, 10:41 PM | #4 |
Have heard that "Softseal" makes the best replacement gasket. Believe they have a website. You want the delux gasket made for the stainless trim. Installing it can be a b~!@#! Good luck
03-10-2003, 11:48 PM | #5 |
Thanx, guys!!
I am prepared for the worst...I have had good luck with a piece of rope and soapy water in the past so I do not forsee any problems. Later... |
03-11-2003, 12:35 AM | #6 |
Roadtrip!
The liquid dish soap works good, the problem may be with the trim. Make sure it stays in the groove. Takes patience!
03-11-2003, 01:04 AM | #7 |
IT'S NOT THAT TOUGH. JUST TAKE YOUR TIME, & DON'T FORCE IT. THERE NO MAGIC INVOLVED. I USE STRIPS OF MASKING TAPE TO HOLD THE TRIM IN THE GASKET, & SPRAY SILCONE IN THE GROOVE & W/S LIP.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
03-11-2003, 01:39 AM | #8 |
Maybe you already know this, but some of that window trim has a deeper channel on it, so you have to order the window gasket for the right depth of trim you have. I made that mistake, and had to reorder the gasket.
