01-11-2011, 03:15 AM | #1 |
C10 addict
What are the benefits of a 73-87 crossmember swap?
Other than the getting disc brakes, is there any benefit to swapping the crossmember off of a 73-87?
01-11-2011, 03:48 AM | #2 |
Re: What are the benefits of a 73-87 crossmember swap?
mahanian i purchased a 74 fr.end/cradle for my 67, i would say convience of having it out to tear down & reasemble & working on it when u want with minimum down time in my case. also i gained a sway bar that my 67 doesnt have
1990 chevy 4x4 with a 1940 IHC body |
01-11-2011, 07:04 AM | #3 |
I am a Referee of life.
Parts are cheaper.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
01-11-2011, 07:11 AM | #4 |
I have a 67 Chevy I am restoring for my daughter. I used a 76 with the power stearing and brakes. It works great. It has a 350 Turbo and a chromed up 250 6. I'm doing a complete frame up.
01-11-2011, 10:36 AM | #5 |
I think in my case the benifit is that I can put in a big block without having to buy special motor mounts. Jim
01-11-2011, 10:49 AM | #6 |
C10 addict
Those are all good reasons, what are the differences in parts compared to a 71/72 crossmember? Are the control arms the same length? I know the 73-87 balljoints are different. I have a 72 crossmember that I was going to install on my 67 and I'm trying to figure out if there is a reason to buy a 73-87 instead?
01-11-2011, 11:20 AM | #7 |
If you have a '72 crossmember just use that one. Some folks like that the 73-87 xmembers have rubber bushings for the a-arms as opposed to the screw in solid ones on the earlier trucks.
I've just found that if you've got a 67-70 truck, it's easier to swap in a completely new xmember so that you can just get parts for a single year if you are doing replacements down the road. |
01-11-2011, 03:08 PM | #8 |
interested to
1969 Chevy c20(Miss Hackjob) |
01-11-2011, 03:34 PM | #9 |
im rebuilding a 74 for my 67 prior comments here suggest that the parts are cheaper but this far into it im faced with the cost/decision of pressing off the A arm shaft bushings and have posted the problem here
http://67-72chevytrucks.com/vboard/s...d.php?t=439872 in hopes of keeping my costs down the problem/costs of pressing out & having them reinstalled are not mentioned in a few posts i read but still would go this way again.
01-11-2011, 03:38 PM | #10 |
Ive done it both ways, the 73+ xmember swap was very straight forward with the exception of some minor drilling. I also have done the 6bolt 88+ 2500 swap with the 3/4 ton lower a-arms and I must say I vote this route if you can swing it and want to maintain a 6bolt front with over the counter parts.. the ride difference between the a-arm bushings (steel vs rubber) was not noticeable for me.. I ran stock height so could be some of the reason.
* 1968 GMC Swb - 98% done (current restoration) * 1971 Chevy Lwb - Retired Dump Hauler * 1982 K10 Longbox - New Dump Hauler |
