01-20-2011, 08:13 AM | #1 |
yes, i do
removing water stains from glass?
so my 72 has water stains/marks that don't come off the glass, mostly on the rear window. is there a trick to get rid of those or am i just gonna have to suck it up and buy new glass? the glass on this truck is great, no cracks or broken glass, just the water stains/marks
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
01-20-2011, 08:31 AM | #2 |
Tot Roddin'
Re: removing water stains from glass?
60ratrod... check out this link as it might provide a solution to clearing the window before you have to purchase a new one.
http://www.67-72chevytrucks.com/vboa...ighlight=glass Also, here's a quick search within the Detailing section using "glass" as the search word: http://www.67-72chevytrucks.com/vboa...archid=2106225
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-20-2011, 08:50 AM | #3 |
yes, i do
hey thanks man. i read the getting scratches out of glass thread and was dreading the possibility of having to use a buffer since it seems to leave depressions and low spots in the glass. i'll look into the chrome polish/cleaner and bar keeper's friend. that's a name i haven't seen since the mid 90's
01-20-2011, 08:53 AM | #4 |
Tot Roddin'
"Hopefully" one of thsoe products will assist you in cleaning up the windows, before you have to use a buffer or replace it all together. Let us know what works and what doesn't.
01-20-2011, 10:11 AM | #5 |
yes, i do
will do when the weather clears up and i get a chance. glass is back burner for now. i have a driver's floor pan and cab mount that needs replaced asap
01-20-2011, 08:12 PM | #6 |
I have used the bar-keepers friend on my glass and it is great,I take a green scotch pad and water with a little B-K on it and scrub it down.Then wipe it off with a clean towel,rag etc.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
01-20-2011, 08:38 PM | #7 |
Redefining LowBudget
I agree ^^^^^^^^^^^^^
also you can just wipe them with 0000 steel wool....I suck at cleaning windows and this works great..nothing wet just scrub them and you can feel them get claen and smooth
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
01-20-2011, 11:19 PM | #8 |
yes, i do
yeah, but i don't know about scrubbing glass with steel wool though. the greeny weeny i'll do, but the steel wool, that will be a last resort
01-21-2011, 07:27 AM | #9 |
the greeenie scares me but the 0000 steel wool islike a cotton bal I even hit the SS around the windows my chrome is kinda ruff (ddstuff) and it keeps that clean too
01-21-2011, 10:54 AM | #10 |
Ive used both but prefer the pad,steel wool u need to be careful around the paint,chrome, metal, etc.
01-22-2011, 12:45 AM | #11 |
Parts and more parts
I have buffed my glass with a polishing compound, like 3M's Finnesse-It and a large buffing wheel and removed water spots.
Frank |
02-15-2011, 05:19 AM | #12 |
"GO DAWGS"
I second the 0000 steel wool. I have used it several times and as piecesparts said, I buffed it afterwards with Finnesse-it or mirror glaze #2 fine cut cleaner.
PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops |
02-15-2011, 06:29 PM | #13 |
Some hard core water stains are not something sitting on the glass. They are actually chemical etchings into the glass and hence almost impossible to get rid of. I had a 69 that I bought form a guy that let it sit under a sprinkler for a whole summer. I worked and worked and worked and finally took it to a glass guy for advidse. The side and back glass was so bad I had to replace it.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
02-16-2011, 11:42 PM | #14 |
I use a sharp razor blade, but you have to know what your doing or youll end up scratching it but it works awsome. I clean windows and glass as part of my job and i use razor blades on all of them.
1969 Chevy c20(Miss Hackjob) |
05-25-2011, 10:43 PM | #15 |
the boss has me cleaning up his 64 f*rd falcon he picked up. he found it sitting in a barn where it was parked in the mid 80's. he had me do a quick cleanup with 0 steelwool and went back over it with 00. the glass was pretty gnarly when i started. it cleaned up really well. i wouldnt b afraid 2 use it on my 65 or my 62 olds.
05-26-2011, 02:33 AM | #16 |
~Rest In Peace~
vingar and water with newspaper
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
08-17-2011, 11:17 AM | #17 |
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
