View Poll Results: Which Bed Sides do you Prefer | |||
1 | 2 | 3.85% | |
2 | 20 | 38.46% | |
3 | 1 | 1.92% | |
4 | 6 | 11.54% | |
5 | 9 | 17.31% | |
6 | 1 | 1.92% | |
7 | 12 | 23.08% | |
8 | 1 | 1.92% | |
Voters: 52. You may not vote on this poll |
01-25-2011, 06:33 PM | #1 |
Stake Body 64 C10 Project
Thought I would put this here to ask opinions. Building a stake bed for my lwb 64 because i think it will end up cheaper than fixing the bed i got with it which needs $$$ in replacement panels. So here goes nothing... Making the frame for it out of 3" C channel and putting flat stock steel along the sides. Should be starting tomorrow or the next day when the steel shows up and some shop space clears.
Here is the poll portion of the thread.... the dang sides. Too many options so i drew up 8 of them and want your opinions. also, I am attaching some ideas for "tailgates" for a stakebed (please forgive a F#$^ and a D*&%#$) any suggestions advice would be greatly appreciated. oh and I know it is a 60-63 cab in the drawings but couldn't find the equivalent drawing from a 64-66 catalog. Last edited by rahatawa; 01-25-2011 at 06:43 PM. |
01-25-2011, 07:21 PM | #2 |
1961 crewcab
Re: Stake Body 64 C10 Project
1,3,4 for me.
here is a stock stake for inspiration..
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
01-25-2011, 08:35 PM | #3 |
If your truck is a Dual rear tire then i agree 1,3,4 if it is a single rear tire then 5
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
01-25-2011, 11:02 PM | #4 |
Chevy Only Tx
4,5 but that's just my opinion. Good luck!!
Chevy Only Tx......... |
01-25-2011, 11:53 PM | #5 |
1961 crewcab
my 63 is a stake bed I guess...
01-26-2011, 10:45 AM | #6 |
It depends...do you plan on using the bed to haul things? What kind of things? That will dictate what style you will want to have
If not just go with what looks good to you Posted via Mobile Device |
01-26-2011, 01:14 PM | #7 |
It is a half ton. Single rear wheel. I took the most popular responses and tweaked and came up with an additional 3 (9*, 10*, 11*, and 12*). I know... more options. But I have time to sort it out and get what i want.
As to what I will be hauling... Dogs, Small Boys in the neighborhood, and anything else i can come up with. I just wanted it versatile. To that end i split some of the side boards to make give it more configurations. It will end up just being what I think looks best but I do want to know what you guys think. and wow didn't think #2 would be as popular. Last edited by rahatawa; 01-26-2011 at 01:24 PM. |
01-26-2011, 01:16 PM | #8 |
01-26-2011, 03:17 PM | #9 |
GMC's n H.D.'s too!
#2 is my favorite, and the way I have been thinking about making my '60.
Either #9, or #12 would tie for second for me. |
01-26-2011, 03:31 PM | #10 |
1962 C-10
I voted for #6, then scrolled down to see that it had already been nixxed. Oh whell...
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
01-26-2011, 03:34 PM | #11 |
Im not a fan of the step down style stake sides. For what you listed having gaps in the boards won't be an issue. I would do 4, 5, or 9 as a solid side will look better than a sectioned one (no matter what you do they will never line up evenly)
01-26-2011, 03:35 PM | #12 |
Senior Enthusiast
Don’t know about which is most practical, but cosmetically I like #5 best.
01-26-2011, 03:40 PM | #13 |
When it comes to steaks... I like RIBEYES and #7
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
01-27-2011, 07:00 PM | #14 |
as for the blue truck with the small sides. I just don't like how small the tailgate would be but the debate still continues...
Also Day One Progress: Metal Cut. Laid Out. Tacked. Finish welding tomorrow. Details. No It doesn't touch the frame in the center but there is zero flex so not worried. Yes there could probably be another cross sill in the rear section between the rear two but didn't plan material for it and don't think it is necessary. I could over build this thing but am not. We will see if I regret it later. The light use it will see makes me doubt it. Also tried to use 3" channel to "level" the frame out for the runners but was going to run into clearance issues with the suspension drop causing tire rub. Moved up to 5" channel and problem solved unless I carry enormous loads. More Tomorrow. Last edited by rahatawa; 01-27-2011 at 07:00 PM. |
01-27-2011, 07:13 PM | #15 |
Redefining LowBudget
As a kid I spent alot of time riding in the back of one of these and if you cut off the 2nd one down on #7 and make it so that there are 2 sections on the sides that would be the truck that started it all for me..it was even the same color
and there was a block of wood cut to even up the frame so the bed layed flat on it.... I was doing a restore when I went off to the Military and it was stolen before I got back from over seas..bummer cuz dad had bought it new...and I learned alot of lessons in that old truck!!
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
01-27-2011, 07:34 PM | #16 |
I really like what you doing, looking forward to more pictures.
I am betting you can appreciate this crazy idea I have.... the following, but as a 60-66. |
01-27-2011, 09:14 PM | #17 |
FIVE. One word: FIVE. FIVE
01-31-2011, 05:00 PM | #18 |
Updates from friday and today. Took the bed off the truck and finish welding the supports. Decided to add a hitch because as soon as i didn't put one on i would need it. Remembered the HD dealer accessory bumper that came with this beast and decided to add it. Then made a panel to cover the rear of the whole she-bang.
Finished that up today and added tail lights. Hoping the weather holds off so I can pull the bed and paint the frame and bed tomorrow. Bumper and all will be black but after its all said and done I may go back and fill the dealer name and location that are cut into the bumper with white paint. Also got the wood ordered so all that is left is paint and wood I think. Drew |
01-31-2011, 07:43 PM | #19 |
they just lift out so so you can have alternative sides for alternative days
ron |
02-02-2011, 02:00 PM | #20 |
awww dang it
There always has to be a "but."
I got the wood for the bed and all of it laid up on the frame to get an idea for weight. My worst fears were realized. My 5" drop springs are too much. See Picture... So truck is sitting on the bump stops in the the rear. Simple solution.. take them off. That gets me 2 1/2 inches. Notch the frame. That buys me all I need but then the first thing to rub would be the bed wood. Not sure i see that as a huge problem. Or relocate bump stops after notching the frame possibly... Neither of these fix the problem of the unlevel truck.. There are 5" drop springs on it now. So order new ones.. 3 or maybe 2 inches? Thoughts are right now to sell the 5" springs to fund some 3" springs and see where I am after that. Then notch the frame if need be. Thoughts? |
02-02-2011, 03:21 PM | #21 |
Zero Albedo
I've been waffling back and forth about whether to stakebed my 3/4 t- this is serious inspiration.
Beautiful work! Could you perhaps get a set of those overload springs to help keep the rear up, but not too much? The ones that look like quarter ellipticals.
Baz "Deserve's got nothin' to do with it." 66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467 65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432 65 Chevy Panel (former U.S.Navy truck) 64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348 64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now) 68 Dodge Charger Last edited by monolith; 02-02-2011 at 03:23 PM. Reason: addendum |
02-02-2011, 04:32 PM | #22 |
Who Me?
Looking good so far. As for the style, it would depend on if its for show or for hauling a bunch of stuff. I like the lower profile ones for the looks.
#2 for me.
Steve 1997 Tahoe LT 4D 2WD (DD) 1961 Apache 10 (sold) 1965 C10 Stepper (sold) Last edited by 61_FL_Apache; 02-02-2011 at 04:32 PM. |
02-03-2011, 02:30 PM | #23 |
Need opinions and I know you guys have plenty! ha.
Have any of you used the HD springs? or Air shocks on these trucks. Need to level this girl up and have some clearance. Notch is starting soon but need some lift as well to keep the ol girl's rear end from sagging. Ideas? |
02-04-2011, 01:50 AM | #24 |
#4 or #5
02-21-2011, 11:52 AM | #25 |
Just wanted to put up a somewhat final shot of the bed. Thanks for all the opinions. Went with number five. Still waiting on HD 4" drop springs to pick the back up a bit. But it carried the finacee,the two boys and a hound dog back there with out much trouble over the weekend (The Mother-in-Law to be got to ride up front). Still want to stain the wood but I am really pleased with how it turned out.
Other than the springs the last thing i need is latches for the corners to tie it all together and make it more solid... |
