best body work GMAW shielding gas?
Is c25 best of straight Co2? It is only a 110v welder so i'm thinking i could get away with 100% with out too much trouble. but c25 would probably be better with the shallower penetration and minimized spatter. what do you think?
thanks, Justin |
Re: best body work GMAW shielding gas?
Stick with the mix. you don't need straight CO2 Either one will work but for thin gauge sheetmetal I would just use the mix. If you already have it, as it sounds it will work
cool thanks for the reply, thats what i thought just wanted another opinion.
I believe the c02 is for penetration and the argon is used for anti-spatter. Some people like the 90/10 mix I have always used the 75/25 but I am thinking I will try out the 90/10
![]() Join Date: May 2007
The more argon, the better. 75/25 is the best compromise between added cost vs. gains. That is why that is the industry standard for mig welding.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
Young Gun
The 75/25 is a very common mix. We use a 85/15 mix here at school. Both have good penetration and yet are relatively spatter free when set right.
1968 chevy c10 soon to have 454 and turbo 4006 1970 custom/20 4x4 454/sm465/np205 around 7 inches of lift with 36's. 1992 ![]() Soon to have a few more upgrades ![]() 2003 ccsb 1500hd |
I know in my highschool job we used 90/10 but we were welding on nasty pipe, and needed penetration. I have never used 75/25 before though.
