02-05-2011, 09:34 PM | #1 |
Speedo cable routing
The 71 k10 i bought has no speedo cable and the firewall has been plugged and caulked to death. Does the speedo cable penetrate the firewall or the floor? Does anyone have a routing diagram showing attachments?
02-06-2011, 04:29 AM | #2 |
Re: Speedo cable routing
Just replaced the cable in my 68 C20 yesterday. It goes through a hole in the firewall at the upper corner of the fuse panel.
On my 68, the panel runs length-wise, and I know some of the newer ones ran more vertical. The hole is about 1" in diameter, about 1/2 way between the steering column and driver's side inner fender, and about 4-5" above where the steering column penetrates the firewall.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
02-06-2011, 04:41 AM | #3 |
here is a picture of where my speedo cable goes through with a gromit, Hope this helps. but if its not correct I am sure someone else will correct me.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
02-06-2011, 06:30 AM | #4 |
Here is a picture of the location where the cable goes through the firewall on a 71 K-10.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
02-06-2011, 11:51 AM | #5 |
Grandpa in the rustmobile...
Jim is correct I believe. Mine came thru right above that wiring block.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
02-06-2011, 02:53 PM | #6 |
Excellent info. Are there connections anywhere along thr frame on route to the tranny?
02-06-2011, 11:48 PM | #7 |
Mine has a clip that slides on the driver's side frame and there is a loop strap that is screwed to the side of the trans.
I will see if I can post some pics.
02-06-2011, 11:58 PM | #8 |
there is also a clip on the cab that you can stick the cable through and then bend it to hold it in place....
02-07-2011, 02:43 AM | #9 |
Here are some pics. My old cable was 69". Options were 60 or 83. Looks like I went too long, but it works.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress Last edited by dmack91; 02-07-2011 at 02:45 AM. Reason: added text |
02-07-2011, 08:56 PM | #10 |
Dmack is that that 80's cable?
02-07-2011, 10:42 PM | #11 |
Is that a gear reduction mounted to the transfer case or is that a stock item. One of the parts in the coffee can that came with the truck looks just like it. The PO told me it was needed for the larger tires.
02-07-2011, 10:46 PM | #12 |
Yours looks extra long lol
02-07-2011, 11:33 PM | #13 |
I think it was 83" - that was the closest thing Napa had.
The gear it goes into (last photo) is on the TH400.
