Old 02-07-2011, 11:18 PM   #1
flamingbig10
6.0 powered square
flamingbig10's Avatar
Dynatech MuscleMaxx Headers
I'm plan on using the Dyna tech 67-69 camaro ls swap headers on my 80 c10 with 6.0 and 4l80e with dirty dingo adjustable motor mounts, would I have any chance these will fit
http://dirtydingo.com/store/index.ph...=1_206_305_318
http://www.speedwaymotors.com/NEW-Dy...LS2,41921.html
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 02-10-2011, 10:44 PM   #2
flamingbig10
6.0 powered square
Re: Dynatech MuscleMaxx Headers
anyone, I guess I order them and see for myself if they'll fit
Aaron
Old 02-10-2011, 10:50 PM   #3
85burb
85burb's Avatar
They LOOK like they would work. But my opinion does not really count due to my headers that looked like they would fit but they hit everything even remotely close to my truck. If they do fit i may ge a set one day.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-11-2011, 02:57 PM   #4
mac72
If you get em keep us posted as I'm headerless at the moment!
mac72 is offline   Reply With Quote
Old 02-11-2011, 03:08 PM   #5
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
my Dynatechs for '70-81 Camaro w LSx swap:
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-11-2011, 07:04 PM   #6
mac72
Kurt those dyna's you got are gorgeous! I would buy a set rt. now but they hang to low for my truck
Old 02-12-2011, 12:41 AM   #7
68GMCCustom
thanks mac. I really wanted to keep everything between the frame rails...but since I'll be staying with a static drop in the front, even if/when I bag the rear, it shouldn't be a problem.
Kurt -
Old 02-12-2011, 12:51 AM   #8
Puropedo
Kurt, from your pics it seem you had to notch the drivers side frame to make the the Rh header fit, did you do any mod(s) to the passanger side?
Puropedo is offline   Reply With Quote
Old 02-12-2011, 01:00 AM   #9
68GMCCustom
nope...didn't have to notch a thing...but if I don't replace my motor mounts with solid mounts and a mid plate.... I'll need to trim them just slightly on the tubes that have the "Dynatech" tab welded to them.
That said...if I moved the motor all the way back against the firewall they'd clear fine.
Kurt -
Old 02-13-2011, 08:23 PM   #10
BigShoe24
True Addiction
BigShoe24's Avatar
68GMCCustom, very nice! Would you happen to know the p/t #? I was wondering what you think the height is from the exhaust port to the lowest point as well. I have a PB cross member so I am hoping that these might hang about flush with the bottom of the frame rail. Thanks
RCC
BigShoe24 is offline   Reply With Quote
Old 02-13-2011, 10:25 PM   #11
flamingbig10
6.0 powered square
its looks like they'll work with a little trimming but they may hang down to low past the frame
Aaron
Old 02-14-2011, 12:18 PM   #12
68GMCCustom
part# is 115-909400 (30C)....but they do hang below the frame by a few inches.
....not sure if the 30C is needed at the end of that part number btw.
Kurt -
Old 02-14-2011, 02:57 PM   #13
mac72
I think the only time you'd have a problem is driving aired out.If you look at his pics no.6 shows how far below the rails they hang.It also depends if your using drop spindles W/ your drop member,I am not & they still look to close for me
Old 02-14-2011, 03:04 PM   #14
68GMCCustom
if it hit something....I'd probably loose the oil pan before the headers.
Kurt -
Old 02-14-2011, 04:42 PM   #15
mac72
yea I hear ya, it looks like their dead even W/ the bottom of the pan & I'm using the same pan you are. Makes me wonder if I should take a shot at them.I already have to sell the dt's I bought [ they hit the firewall] really dont want to have to do it again!
Old 02-14-2011, 06:49 PM   #16
68GMCCustom
isn't your motor positioned way back?
Kurt -
Old 02-15-2011, 08:30 AM   #17
BigShoe24
True Addiction
BigShoe24's Avatar
Don't mean to highjack the thread, but mac72, your running a DM correct? It's been a while since I order mine, but thought it raised the motor something in the range of 2". Is that right or am I just telling myself this so I'll order these headers, lol.
Mac72, are the DT's 1&5/8" ?
RCC
Old 02-15-2011, 02:51 PM   #18
mac72
Kurt,Thats what I was thinking but looking at your pic no.7 it looks to be about a .5" further back than yours.It may be up higher though like big shoe stated.If you remember that post on the high hump I think mines a little higher in the bay Hmmmm.
bigshoe24,My crossmember is from suicide doors but it does look like the early porterbuilt units & I didnt inquire about wether or not it raised the mtr. or not.The mounts are ls specific & it fits although it is tight at the front of the pan & the crossmember.Some of this has to do w/ the tranny crossmember placement also.
Yes the dt's are 1 5/8" they are nice headers but the drivers rear tube hit my firewall.
Old 02-15-2011, 10:31 PM   #19
BigShoe24
True Addiction
BigShoe24's Avatar
Very tempted to order these. I'm going to call Dynatech and see what the difference is between the 70'-81' camero and the 67'-69' . The p/t # you gave matches the 67' -69' btw
RCC
Old 02-16-2011, 11:59 AM   #20
68GMCCustom
mine are the 1 7/8" x 3" coated... I bought from Speedway, off this page:
http://www.speedwaymotors.com/NEW-Dy...LS2,41927.html
If you go to the Dynatech page you'll see that they also offer various stepped headers also but for sbc.
http://www.afabcorp.com/AFCO_Dynatec...uscle_camaro70
....but they only offer the 1.88" (actually 1 7/8") in 2.5" on their page....so obviously the 03C on Speeday's refers to a 3" coated header...since they show 025C is 2.5".
only this one (mine but 2.5" reducers) is listed as LSX and is not stepped...others are for sbc:
115-90940025C 1.88 LSX 70-81 Camaro Hdr Coated w/2.5" Reducers $399.99
and here are the '67-'69 numbers:
115-91140025C 1.88 LSX 67-69 Camaro/68-74 Nova Hdr Coated w/2.5 Reducer $399.99
115-91140030C 1.88 LSX 67-69 Camaro/68-74 Nova Hdr Coated w/3.0 Reducer $399.99
Kurt -
Old 02-21-2011, 09:16 PM   #21
flamingbig10
6.0 powered square
I'm going to go for it with 67-69 camaro headers
Aaron
Old 02-22-2011, 01:52 PM   #22
mac72
Make sure you let us know how they fit!
Thnaks Mac
Old 02-25-2011, 02:38 AM   #23
shrunken66stroker
shrunken66stroker's Avatar
X2^
shrunken66stroker is offline   Reply With Quote
Old 02-27-2011, 04:17 AM   #24
flamingbig10
6.0 powered square
I called speedaway motors and they said they don't carry the 67-69 headers any more and summit is back ordered for 2 weeks
Aaron
Old 02-27-2011, 02:56 PM   #25
shrunken66stroker
I wonder what the difference between the 67-69 vs. 70-81 camaro headers? If it's the same part number then I assume it's the exact same part. Are there no other swap headers that will fit these trucks?
