Old 02-08-2011, 07:48 PM   #1
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Full Time 4x4 T-case, only turns front shaft!
I have a 1985 Chevy half ton thats been frankenstined by the previous owner, so I don't know what is stock and what isn't. What I do know is that the transfer case doesn't have a 2wd option. (Military?) Anyway, I tried to move the truck the other day and it wouldn't move when I put it in gear. I looked under the truck and saw the front shaft turning, but not the rear! So I locked the hubs, but it still wouldn't move. (I think one of my hubs isn't locking)
Is this a common problem/symptom? What's broken?
1978 C3500 Crewcab (Project)
1979 C2500 Crewcab (Driver/project)
1988 R2500 Crewcab (Driver)
1988 V3500 Crewcab
1988 R2500 Crewcab (Mint, Ex Fire Dept)
1968 Chev Suburban (4x4 conversion) LINK
1970 Chev C20 Suburban (driver/cruiser)LINK
2005 Impala (Incognito vehicle)
2004 Yukon XL Denali (Kid hauler)
1947 Case tractor
Facebook Page(1000's of pictures of GM cars and trucks organized into albums)
YouTube Channel
Mr Pops is offline   Reply With Quote
Old 02-08-2011, 08:18 PM   #2
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Re: Full Time 4x4 T-case, only turns front shaft!
If it's a full time transfer case (203) with manual front locking hubs and it doesn't have a part time conversion in it. Odds are something is burnt up.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 02-08-2011, 09:43 PM   #3
OrrieG
OrrieG's Avatar
Not an expert but sounds like the rear output shaft or spider assembly broke. Was it running before? Can you turn the back drive shaft with the transfer in neutral pushing it (no power applied from the transmission). If the front shaft turns then the chain and that engagement is working somewhat. I suspect you will find the back drive line locked up as well.
OrrieG is offline   Reply With Quote
Old 02-09-2011, 07:46 AM   #4
Blazer1970
Blazer1970's Avatar
If it is a full time case (NP203), and you tried to move it with the front hubs unlocked, what you describe is exactly what would happen. The front shaft would spin and the truck would go nowhere. That is normal operation for a 203. An '85 would have come stock with an NP208 though.
Blazer1970 is offline   Reply With Quote
Old 02-09-2011, 07:55 AM   #5
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Ok, so it probably boils down to the fact that one of my manual hubs isn't locking.. Come to think of it, I tried to move it last year with the rear driveshaft off, and it wouldn't move then either.
Thanks for all your input guys!
1988 V3500 Crewcab
1947 Case tractor
YouTube Channel
1985, chevy, full time 4x4, t-case, transfer case
