02-08-2011, 10:16 PM | #1 |
any new duramax swap info for 67-72 c20 or c30
have a 71 c20 suburban with low miles, 38k. debating a 402/4l80e original looking or a 06-07 duramax/allison swap. the truck is stock and clean, plan on using it as a shop/family car to tow more 67-72s home. it ia also being lowered 6/7"s. any info would be greatly appreciated. thanks, glen
my build threads, 68 pro touring, auto cross c10 (mid life crisis) http://67-72chevytrucks.com/vboard/s...d.php?t=464109 website http://www.sauersgarage.com/ |
02-08-2011, 11:29 PM | #2 |
Formerly- 1972SuperCheyenne
Re: any new duramax swap info for 67-72 c20 or c30
First off, beautiful Suburban! I vote for the Duramax/Allison combo. The Duramax truck I had would pull anything I hooked to it like it wasnt there. That would absolutely make that truck! Hope to see a build soon, and if it looks like your other build I know it will be amazing!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
02-08-2011, 11:36 PM | #3 |
arent those allison trannys like 4 feet long!!!!
02-09-2011, 12:53 AM | #4 |
On the college boy budget...
I am by no means an expert on this, but from things I've read in the past it would be a real PITA to put a Duramax combo in one of these trucks and if you're dead set on running a diesel your best bet by far is to get a Cummins and put that in as the swap is much much easier. I have heard the option of taking the 67-72 body and putting it on a factory Duramax frame but I don't think I've actually seen that done anywhere.
Again I am no expert and don't have any direct experience doing any one of these swaps but that's just the gist I've gotten from things I've read on here and other places.
-'68 C10 short/step- 350/350 |
02-09-2011, 01:25 AM | #5 |
PPE did one in a 70 2wd. Here is their website. They have all the stand alone controllers you will need to make it happen. A google search will bring up a bunch of articles on their pickup as it was in Diesel Power mag and others. Your best bet, and probably the cheapest, would be to find a wrecked duramax to pull the engine/tranny out of so you will have everything there.
EDIT: Here is the DP mag article.
Name: Les ---------------------- Couple 80s Couple 70s One 68 Last edited by Maxxd07; 02-09-2011 at 01:38 AM. |
02-09-2011, 09:07 AM | #6 |
Beautiful suburban! Just curious, but why would you lower it so much if you want to use it as a tow vehicle?
02-10-2011, 08:03 PM | #7 |
6>8 Plugless........
Very nice suburban! Good luck with the swap, it will be a lot of work but awesome when completed!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-10-2011, 08:14 PM | #8 |
thanks, been doing homework all week. i might be in over my head? still think i am going to go for it.
02-10-2011, 11:12 PM | #9 |
Good luck, I already like your current build - so I can't wait to see this one!
I always liked Matt Hughes 66' http://truckin.automotive.com/93128/...c10/index.html
72 Cheyenne shorty "CheyLow" 72 3/4 long 4X4 69 SWB "Prospector" 68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled" Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com |
02-10-2011, 11:19 PM | #10 |
That is a super sweet truck!
02-11-2011, 12:40 AM | #11 |
My father has a Dmax and he'll never go with gas again, when we pull trailers we forget the things are behind us and these are dump trailers, enclosed trailer, and flat bed car trailers loaded down not some 8ft by 10ft quad trailer. I want to see this swap so go for it
1969 Chevy c20(Miss Hackjob) |
02-11-2011, 12:53 AM | #12 | |
I am doing a duramax swap right now in to my 67 crewcab i am putting it on the 2002 frame here is a link http://67-72chevytrucks.com/vboard/s...d.php?t=358024 hope this helps I did not like the ppe stand alone harnes. I have alot of pics
02-16-2011, 07:52 PM | #13 |
found a core. looks to big for a lowered 2wd. may shelve it for a 4x4 with 4" lift and 33s
02-16-2011, 11:30 PM | #14 |
Just curious, but why go to the trouble to lower it if it will be a tow vehicle?
03-01-2024, 12:28 PM | #15 |
What engine mounts did you use? Dmax.com?
03-05-2024, 07:33 PM | #16 |
driving is in my blood
Not sure why a couple people think lowered trucks can't tow. Do it
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
03-07-2024, 05:35 PM | #17 |
Ok I will be the first to say it. 6.0 LS bored and stroked to 408. Small cam. This combo would pull well and take 300-400? pounds off the sub compared to the Duramax? With the 4l80E 3.73 or 4.10 gears?
