Old 02-09-2011, 01:18 AM   #1
Gordonr1973
Home Built '87
Gordonr1973's Avatar
4L80E Install --- just the basics...
Hi,
I'm installing a 4L80E tranny behind my LQ9 6.0L in a '87 SWB 2WD and I'm searching for just the basic steps of how to bolt up the tranny to the motor.
Are there any threads outlining this with pics that anyone knows about? Any sites that might list out the parts I need to do this as well (seals and gaskets?)
I've done some searching and the best I've found todate is this one:
http://www.ls1truck.com/forums/front...rans-swap.html
Any leads are appreciated!! Thanks!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 02-09-2011, 08:08 PM   #2
clinebarger
Re: 4L80E Install --- just the basics...
What flexplate do you have? Pics would be great. Is your 4L80E out of a LS equipped truck?
I tried to read you link...They started off by bashing the 4L60E...So I closed it
clinebarger is offline   Reply With Quote
Old 02-09-2011, 10:45 PM   #3
Gordonr1973
Home Built '87
(I'm not a fan of LS1truck so much b/c there tends to be a lot of bashing there.)
My motor is in the shop so I don't know the flexplate specifically, but I'll try to dig up some pics...I don't know what the motor that was orginally infront of it as it was out of a different truck from the LS motor I have.
Gordon
Old 02-09-2011, 10:57 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
What year is the motor and do you know what the motor came out of? Cadilac?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-09-2011, 11:16 PM   #5
BigShoe24
True Addiction
BigShoe24's Avatar
I am installing an 4L80E with an LS3. Here is what I believe is going to work. This is GM p/t #12621399 and comes with spacer. I actually just got mine today. I started a thread on here that I plan to document every step.
RCC
BigShoe24 is offline   Reply With Quote
Old 02-09-2011, 11:48 PM   #6
Gordonr1973
Home Built '87
Motor was out of a 2WD 2004 Chev Silverado SS
Tranny was out of a 2WD 2003 CHEVROLET SILVERADO C3500
I used http://www.motoverse.com/tools/vinDecoder.asp to decode the VINs
Gordon
Old 02-09-2011, 11:51 PM   #7
Gordonr1973
Home Built '87
See, this is what I am trying to understand....what on the flex plate bolts to the tranny?? We have totally different flex plates but I guess maybe that is my problem --- I need to change mine and get the spacer you mentioned.
How did you figure out what kit to buy?
Gordon
Old 02-10-2011, 01:40 PM   #8
BigShoe24
True Addiction
BigShoe24's Avatar
There are a couple threads on here and other sites that explain it. Basically, the converter that goes with a 4L80E has six bolts to the fly wheel, and the snout 'center piece' isn't as long as other converters in which the spacer adapts for. Good luck.
RCC
Old 02-12-2011, 11:19 PM   #9
Gordonr1973
Home Built '87
Any other leads to specific threads / sites anyone is familiar with?
Gordon
Old 02-16-2011, 11:50 AM   #10
Gordonr1973
Home Built '87
Thanks for the replies.
For anybody searching this thread topic: I bought GM part number 12621399 (new flex plate and adapter with bolts) and I ordered new bellhousing bolts as well.
I will put a detailed summary of how I mounted the tranny in my '87 build thread for anyone looking for that info. Thanks!
Gordon
Old 02-22-2011, 11:37 AM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Hmm, I have a 2003 lq4, and a ~98 4l80e. My flywheel looks completely different than the OP's, any way to tell if I NEED the spacer?
Not trying to hijack, figured it was on-topic.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-22-2011, 07:07 PM   #12
clinebarger
LQ4s came from the factory with 4L80Es or NV4500s. You already have the spacer & correct flexplate. Remove the flexplate & see what I mean.
LQ9s were only available with 4L60E/4L65Es Thats why the OP has to buy the spacer & flexplate to run a 4L80E.
Old 02-23-2011, 11:30 AM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
werd, thanks!
4l80e, lsx, swap, tranny
