Old 02-21-2011, 11:55 AM   #1
kSStamp0182
LSX addict
kSStamp0182's Avatar
Steering Gearbox Frame support upgrade needed.
where the steering gear mounts to the frame on my '82 2WD seems like it started to crack at some point in time, and some genius decided to repair it with some good ol' JB weld. LMC offers a Frame Support Kit (34-1590) but it says it is for a 4WD. is there any difference in the 2wd gear box mounting vs the 4x4?
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration]
kSStamp0182 is offline   Reply With Quote
Old 02-23-2011, 07:17 PM   #2
royo
royo's Avatar
Re: Steering Gearbox Frame support upgrade needed.
ORD also has a frame support for Chevy's
nickle and dime
royo is offline   Reply With Quote
Old 09-24-2012, 09:46 PM   #3
txclassics
every one seems to say the same thing "ORD has a repair kit" but no were do i seem to find the answer if it will work on a 2wd truck.
txclassics is offline   Reply With Quote
Old 09-25-2012, 06:53 AM   #4
andrewmp6
I would email or call ORD and ask,I think it might because some over the knuckle kits use a 2wd steering box not sure if that bolts in or not.
andrewmp6 is offline   Reply With Quote
Old 09-25-2012, 08:19 AM   #5
jjzepplin
jjzepplin's Avatar
I have a 4wd frame that has a 2wd box on it (72) I think they are the same as my 4wd looks the same. I am going to cut the piece that mounts the box out of my bent 4wd frame and reinforce the 2wd with it. I think the 4wd cracks more often so they advertise more for them. Nowadays we are putting larger rims on our 2wd's creating more stress on the mounting of the box (weak link). This has been happening with 4wd's for a long time.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-25-2012, 04:10 PM   #6
Bad Karma
Magnificent bastard
Bad Karma's Avatar
The frame cracked under the box on my '77 Suburban. The kit for the 4WD will NOT fit, I have one in a box at home to prove it... I just welded the crack closed on mine, it wasn't that bad.
There are 2WD repair plates out there, but you'll have to hunt them down. They're a little more expensive than the 4WD version.
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
gearbox, steering box
