Old 03-06-2011, 11:11 PM   #1
McNugget
McNugget's Avatar
Question 4x4 Conversion on 71 Cheyenne
I have 1971 Chevy Cheyenne that I am trying to convert to 4x4. I have frame with NP205 transfer case and automatic transmission. I am still looking for the front driveshaft, but my question is, how long will the conversion take? At first I just want to mount everything onto the new frame, cause I will not have the front driveshaft or linkage for the transfer case, but I am going to worry about that part later. I just need to get my truck on this frame and get rid of the 2WD frame asap. Does anyone have any tips? just about everything is on the frame except cab mounts...?
McNugget is offline   Reply With Quote
Old 03-06-2011, 11:13 PM   #2
Gene
Gene's Avatar
Re: 4x4 Conversion on 71 Cheyenne
It depends on how much time you have to devote to swapping everything over. Just swapping everything over shouldnt take all that much time. I've found that it's all the "little things" that seem to take up most of the time. BTW i'm swapping a 2wd to a 4wd also, but I am doing a complete frame off resto in the process. Mine has been going on for 10 months now
Gene is offline   Reply With Quote
Old 03-06-2011, 11:16 PM   #3
McNugget
McNugget's Avatar
Well its my daily driver, but I could devote as much time as it would take at the time its getting done. Could I do it in a week if it is worked on everyday?
Old 03-06-2011, 11:17 PM   #4
Gene
Gene's Avatar
Daily driver? I would suggest borrowing something else to drive in the meantime.
Old 03-06-2011, 11:19 PM   #5
McNugget
McNugget's Avatar
Oh I would def have another vehicle to get around in. I would just want to get it done as fast as possible. I just don't know how much time to expect it to be torn apart/undrivable?
Old 03-06-2011, 11:33 PM   #6
1969K10
1969K10's Avatar
break it down into a couple of jobs?
get the front axle mounted.
get the x-fer mounted.
then work on the little things as they come along. each of the above is a good weekend job, maybe a little more. but then you're not down for 2-3 weeks straight
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 03-07-2011, 07:56 PM   #7
Joesjunk
Joesjunk's Avatar
These are pretty easy to do, Get the 4x4 chassis as complete as possible, engine, trans, axles, ect, then just swap your body over. I have done several, if you have experince with these trucks, and the chassis is complete, the body swap can be done in a weekend
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
1971, 2x4 to 4x4, 4x4 conversion, cheyenne
