motor exploder
Got some jewelry today...
Thanks to everyone'e favorite 'man in brown', I received my new Morel Sportsman roller lifters this afternoon for my 468 BBC. Before you ask, yes it is a hyd roller (aka squishy roller, or 'girlie cam' as they refer to them at Team Chevelle). Got these from Chris Straub @ Straub Technologies. He's also cutting me a custom roller cam to make these babies go up and down in a big way. I had my heads flowed, sent him the #'s and my combo down to the last little detail and bit the bullet.
I had my heart set on running a solid roller, since hyd rollers and big blocks usually mean valve float before 6k, but these lifters are supposed to be good to 7k with the right springs (which I'll be getting from him) - he's cutting me a cam for peak power around 6200-6400rpm with a torque curve that hopefully looks like a Duramax diesel ![]()
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
Re: Got some jewelry today...
very nice its alwasy a good feeling when you get something in the mail for your truck..
With the right spring you shouldn't experience valve float. I have a SBC with hyd roller lifters and had my N/A setup running 7k+ a few times with no issues. Lighter valvetrain components would probably help as well.
Good luck with the combo, a BB runing 6500+ rpms will be nice. Have you done any work to the TKO 500? That's going to be a lot of weight and torque for that trans.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time |
motor exploder
Taking it to Standard Transmission in Ft Worth, TX this coming Tuesday along with my 12 bolt rearend. They're gonna rework the TKO a bit and put some carbon fiber synchro's in it to clean up the high rpm shifting.
I already had the TKO behind the motor before I took it out for this rebuild and it did fine. Supposedly, that 500ft-lb rating is the continuous torque rating, it will handle a peak of 700lb-ft. Same for the TKO600, it is rated at 600 continous, 800 peak. I don't know if all that is bs or not. I do know the guts are the same, just that the 500 has the lower 1st, which I knew would help me get out of the hole a little better with the 3.73's.
It's Better With Nitro
...looks like it would complement my recent jewelry purchase...
motor exploder
Wow, TD Machine!!!!
![]() Those are the goods!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 03-10-2011 at 04:11 PM. |
Im Jelous. May be in a few months ill start working on it. Should get my heads ported first.
69 c-10 BBC ![]() 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles. ![]() |
Nice pieces good luck with the build.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#9 | |
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 03-11-2011 at 12:00 PM. |
motor exploder
Those Lunati's are probably the same type lifters I have, since Morel makes the higher end Lunati HR lifters. Those numbers aren't too far off what Chris Straub said I'd be making. I'm mainly just looking for big, broad torque with a nice little kick upstairs. I'll probably be shifting at 6500rpm on the track, so there was really no point in getting a SR cam other than the bragging rights. Of course all that bragging goes away when you lose a lifter and needle bearings get friendly with the rest of your motor
![]() I did order my springs yesterday, a set of Crowers with 200# on the seat and 560# open. Hopefully I can get this baby up and moving soon, I'm tired of tripping over parts laying in my garage!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 03-11-2011 at 02:38 PM. |
Tags |
454, 468, bbc, roller cam |
