Old 03-12-2011, 12:05 PM   #1
NW Task Force
NW Task Force's Avatar
Question Under bed fuel tank solutions for 55-59 pickups (under $300.)
I was wondering if anyone knows a source for fuel tanks for the 55-59 Chevy/GMC crowd. I would like to get an under-bed setup for $300. or less. It doesn't matter what material it is made of. I also need it to be compatable with my stock fuel gauge. Any suggestions, sources, and part #'s would be appreciated greatly!!!
1957 Chevy Pickup 1/2T, stepside, big window, 77' Camaro subframe, 3rd gen Firebird rearend w/3.23 gears & disc brakes, 66' 283cid, TH350 auto, everything else is original
NW Task Force is offline   Reply With Quote
Old 03-12-2011, 01:52 PM   #2
blackdiesel
blackdiesel's Avatar
Re: Under bed fuel tank solutions for 55-59 pickups (under $300.)
69 mustang tanks 129 bucks, is what I used.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 03-12-2011, 06:57 PM   #3
NW Task Force
I would be interested in seeing some pics of this setup. Did you use the 69' sending unit as well?
Old 03-12-2011, 02:15 PM   #4
candyx
candyx's Avatar
I had one made at Boyd Welding down in Florida,aluminum well constructed.
candyx is offline   Reply With Quote
Old 03-12-2011, 02:23 PM   #5
lakeroadster
Here is an article: http://www.webrodder.com/article.php?AID=442&SID=2&CID=
lakeroadster is offline   Reply With Quote
Old 03-12-2011, 08:36 PM   #6
blackdiesel
No I have an LS motor so I used and chevy late model intank pump and unit. Search for mustang tank several guys have used it.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 03-12-2011, 09:42 PM   #7
floridasteve
floridasteve's Avatar
I used the mustang tank as well. Ebay has them on the inexpensive side. I used the GM sending unit and tweaked the float and sending unit. I have not tried the sending unit yet but I expect it all to work out.
One day I am going to finish this project!
1949 Chevy 1/2 ton
floridasteve is offline   Reply With Quote
Old 03-12-2011, 09:49 PM   #8
bfink
i used a summit racing fuel cell , 25x17x9" , has a built in 90ohm sending unit . i just drilled out a few rivit's and moved the very rear x-member back 2-3 inches and used summits mounting brackets ( you could make your own) i dont know how the filler is gonna work yet as i havent put the bed back on yet . 159.95 for the fuel cell , 32 bucks for the mounting brackets
bfink is offline   Reply With Quote
Old 03-12-2011, 10:36 PM   #9
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
This one will work.
http://www.tanksinc.com/index.cfm/pa...prod/prd83.htm
ChuckDriver is offline   Reply With Quote
Old 03-12-2011, 11:10 PM   #10
NW Task Force
Originally Posted by ChuckDriver View Post
Thank you for the link! Is this the tank you put on your truck? I am basically looking for something that is bolt-in and go! The tank in the link seems to be a simple design and some straps to put it up. It looks like the sending unit is sold seperately.
Old 03-13-2011, 12:43 AM   #11
beanyard
did you end up using the mustang tank as a top fill or a rear fill?
beanyard is offline   Reply With Quote
Old 03-13-2011, 09:18 AM   #12
ChuckDriver
I didn't use that particular one, but mine is from Tanks, it was their universal tank they made in the past in steel. I don't think they make it anymore. It looks like the poly tank would fit betwenn the frame rails real nice and not hang down to low. As far as it working with the stock gas gauge, you would have to match the sender's resistance, and I don't know what the stock gauge range is. Are you planning a EFI engine for your's, if not you wouldn't need the in tank pump. Good luck!
Old 03-15-2011, 11:44 PM   #13
NW Task Force
I honestly like the looks of this tank! The price is affordable and it seems to be a direct fit. They also sell the GME sending unit for 0-30ohms (for my factory gauges)........only $30. This looks like a winner!
Old 03-16-2011, 12:55 PM   #14
OrrieG
OrrieG's Avatar
Poly is ok if it is protected, I had a steel auxilary tank in the spare tire location originally and decided to go with the aluminum one after looking at all the dents and scrapes in the steel one from off road use. If you are going to just be driving around town and its tucked up high enough to avoid parking bumpers, etc. then it should be ok lots of guys use them.
OrrieG is offline   Reply With Quote
Old 03-16-2011, 08:43 PM   #15
ChuckDriver
I think it will be a good choice, let's see some progress pics!
Old 03-17-2011, 08:28 AM   #16
lakeroadster
Originally Posted by NW Task Force View Post
..... They also sell the GME sending unit for 0-30ohms (for my factory gauges)........only $30. This looks like a winner!
That sending unit is a "universal adjustable style" that will work with about any tank. Brother's P/N ATK59SU will work also.
Old 03-26-2011, 05:55 AM   #17
Barney Rubble
Barney Rubble's Avatar
this thread is gold.
Getting the tank out of the cab is my first move.
Bookmarked.
Barney Rubble is offline   Reply With Quote
Old 03-15-2011, 02:46 PM   #18
Maximus
Maximus's Avatar
Does anyone know the Ohm reading between ford and GM?
I plan on using aftermarket gauges and thought it would be easier to use the mustang tank with the appropriate Ohm settings...
Anyone know what those Ohm readings are?
Maximus is offline   Reply With Quote
Old 03-15-2011, 03:00 PM   #19
lakeroadster
Got this off a Ford Mustang blog. They were discussing a 1965 mustang sending unit:
FYI the fuel sender can be read with an ohm meter. The reading when empty is approximently 73 Ohms and when full approx. 10 Ohms. Ford went to a different resistance rating for their fuel senders in the, I believe, early 80s. It is 240 Ohms empty and 33 Ohms full
This matches ohm readings if you got to Jegs for fuel gages. They have:
0-30 ohms (our old Chevy Trucks)
0-90 ohms (Chevy Trucks newer than ours)
240-33 ohms (80's and up Fords as discussed above)
73-10 ohms (like the '65 mustang discussed above)
Old 03-15-2011, 04:16 PM   #20
Maximus
Maximus's Avatar
Thats what I found duringg my searching but it was such an unusual range that I thought it was incorrect...
Thanks!!!
Old 03-15-2011, 04:30 PM   #21
lakeroadster
Thanks!!!
It's F-O-R-D stuff... they wrote the book on unusual.
Stick with the Bowtie... much less confusing
On one of my previous projects I built a '27 Ford Hot Rod Roadster Pickup. I got a great deal on a $500 '85 Mustang GT that I used for the motor & tranny (5.0HO and 4-speed manual). By the time I was done buying / fabricating all the wierd brackets and pieces parts to make it fit/work I would have been money & time ahead using the tried and true SBC and Muncie combination.
Like my signature line states: A smart man learns from his own mistakes, a wise man learns from the mistakes of others.
