Old 03-15-2011, 02:19 PM   #1
rich0313
Lowering a 78 Suburban
I'm in the process of lowering my 78 suburban 2wd and have already dropped the front 4 inches. Looking to drop the back the same with lowered leaf springs, but can't seem to find this part anywhere. I tried Brother's, but was told their springs wouldn't work for my burb. Anyone know where I can get some 4 inch lowered leaf springs?? Thanks!
rich0313 is offline   Reply With Quote
Old 03-15-2011, 07:02 PM   #2
79gmcclassic
79gmcclassic's Avatar
Re: Lowering a 78 Suburban
pics?
1979 GMC Sierra Classic
Freshly lowered 5 inches
79gmcclassic is offline   Reply With Quote
Old 03-15-2011, 07:07 PM   #3
justpball
justpball's Avatar
do a flip kit.
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 03-15-2011, 07:17 PM   #4
rich0313
001 by isaacsmom2010, on Flickr
Bought it off the original 83 yr old owner that used it as a hearse.
Old 03-15-2011, 07:20 PM   #5
justpball
justpball's Avatar
very nice!
87 Crew SWB
Build for the crew
90 burb 2wd
Old 03-15-2011, 07:37 PM   #6
rich0313
Any suggestions on which flip kit? I see that some say 6 inch and I only need 4. Or do you use hangers with the flip kit? I'm confused. If you can explain I'd be very appreciative. Thanks!
Old 03-15-2011, 08:26 PM   #7
SBTork
Garage wrench
SBTork's Avatar
The flip kit puts the rear axle over the leaf springs as opposed to it's stock location under the springs. It's just the flip kit, you do not use shackles or hangers, and it uses the stock springs. It nets about 6" or so of drop. I will post some pics of mine in my thread once I get to my home computer.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 03-15-2011, 11:43 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
a woody?sure in nice shape
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-16-2011, 02:17 AM   #9
SBTork
Garage wrench
SBTork's Avatar
here is mine, flip'd rear......
-Adam
Old 03-16-2011, 10:23 AM   #10
rich0313
Thanks, I was looking to do lowered leaf spriings because I need to replace mine anyway. I found a flip kit that does 4 inches so I think I'm good to go. Hopefully will be done soon and I can post pics then! Thanks for all your help.
Old 03-16-2011, 08:03 PM   #11
rich0313
SBTork - how low did you drop the front? I dropped the front 4 and don:t want to drop the rear lower and I think a 6 inch flip will?
Old 03-16-2011, 08:11 PM   #12
SBTork
Garage wrench
SBTork's Avatar
For the front I cut one full coil from the stock coils, then added 2.5" drop spindles. It will be on air soon though.....
The rear on mine is flipped and is dropped a tad more than 6" I think, that and any lower will require a c-notch or step notch to the frame, which I also plan on doing.
-Adam
Old 03-28-2011, 03:50 PM   #13
b.eddy's72
b.eddy's72's Avatar
The flip kit will give you an approximate drop. You really want to get a closer measurement than climb under with a tape measure and measure the axle from perch to bottom of axle then add the total thickness of the spring pack. It should be about 6 inches depending on the thickness of the springpack. If you say you need to replace your springs anyway then go with a heavier spring with less springs in the pack and you will get less drop.
You could also do the flip and relocate the spring hanger to make up for the extra 2 inches the filp gave.
Just suggestions Good Luck
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new.
66 GMC Short Step, 84 Front Suspension, many more mods to come
67 Chevy 3/4 Ton, 327, Auto, Factory A/C
Ya must have been movin cause I was haulin a*$ when I passed you
b.eddy's72 is offline   Reply With Quote
Old 07-29-2011, 09:43 PM   #14
abigaillozano
I didn't know subies can become a hearse, but that is one interesting application of this classic!
@SBTork, have you installed your air suspension already? Shows us some pictures of that mod please!
________________________________
A good sport truck is a lowered one!
abigaillozano is offline   Reply With Quote
Old 07-31-2011, 10:29 PM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
I've seen some since being around here
would be a nice find most are driven slow and well maintained
John
Old 07-31-2011, 10:47 PM   #16
b.eddy's72
b.eddy's72's Avatar
Here is my sons Burb......The axle was on the bump stops there but they have been cut off and Axle is on the frame now. I have the materials for the c-notch just need time to do it. The receiver hitch is now 1/2 inch from the ground. It has a flip kit and 2 inch rear schackles and about to also have 2600 bags.
Old 08-01-2011, 12:58 AM   #17
SBTork
Garage wrench
SBTork's Avatar
No bags yet, but very soon. I will keep you posted!
-Adam
Old 11-13-2014, 04:57 PM   #18
Alfiguret
Alfiguret's Avatar
you can use the main leaf spring of suburban but fix it under rear axle instead of upper of axle.
Alfiguret is offline   Reply With Quote
Old 12-10-2014, 12:05 AM   #19
Ice&burban
Ok here's a question. Why couldn't you use a 3" drop spring for pick up? With the added weight of the burb, wouldn't that give you around 4"? Would this work or not?
Ice&burban is offline   Reply With Quote
