Old 03-17-2011, 02:18 AM   #1
JeeperJoe
Operation Blackout
The beginning
This is my 1965 Chevy C-10 rust bucket! I have initial plans to do a complete frame off semi custom truck to be used as a driver not a show truck. I want it nice but and I want it very drivable. My plans are to rebuild the 327. I have a 650 edlebrock with an aluminum intake and a mild cam. I am ditching the three on the tree for a 700R4 automatic transmission. I already have 21/2 dropped spindles and disc brake converting to 5 lug. I am replacing all tie rods, ball joints, etc. I bought a new power brake setup with a complete set of stainless brake lines. I am also swapping out rear end for a 5 lug. Plans are to set it on airbags and run about 31/2 front and 5 in rear. I also removed the tank from inside and I am placing it in the rear. I am also placing the battery behind the seat and my fuse block for easy access. I have a complete new wiring harness. I have a 1990 tilt column that I am going to try and use, have not tried yet. Any advice or comments along the way are appreciated.
JeeperJoe is offline   Reply With Quote
Old 03-17-2011, 02:41 AM   #2
JeeperJoe
Re: Operation Blackout
Frame before paint
Old 03-17-2011, 02:50 AM   #3
JeeperJoe
Work in progress
Old 03-17-2011, 02:54 AM   #4
1966JSM
keep it up! i thought about blacking my truck out but came up with something else lol
1966JSM is offline   Reply With Quote
Old 03-17-2011, 10:20 PM   #5
coastierider
What are you using to remove the paint? It's been taking me way too long, im using a random orbital with 60 grit... just curious
coastierider is offline   Reply With Quote
Old 03-22-2011, 01:18 AM   #6
JeeperJoe
Started with stripper but paint remover pads for angle grinder works best.
Old 03-22-2011, 03:08 AM   #7
JeeperJoe
I have had a lot of rust rats working on this truck. I found a cab roof in Arizona and had it shipped. That was fun but mine was really ate out. I have had to replace floor, cab supports, rockers, cab corners and several hand fabricated parts. The cab is coming along though. I am replacing front suspension with 2.5 dropped spindles, disc brakes and air bags. I replaced the original rear with a 90 truck 5 lug with 3.42 gears. I hope to have it back together enough by this weekend to call it a roller again.
Old 03-22-2011, 03:13 AM   #8
JeeperJoe
Can anyone give me details of putting in a rear gas tank or fuel cell. I have looked at Blazer, Fuel cell and Camaro. Any advice from someone that has had a good install please help.
Old 03-22-2011, 07:41 AM   #9
k1rodeoboater
how far you planning on lowering and what do you want for fill options? In bed? Side fill? Rear fill?
If you're slamming and want side fill lakeroadster's tank idea is the best bet if you want an under bed...though I'd say at that point you're better off doing an in the bed tank or keeping the in cab tank. His sticks down the least (aside from some fuel cells)
Camaro is good for rear fill and a fairly easy install if you do it with the bed off. No modification to the frame aside from drilling holes in the cross sills to mount the bracket up. It's also the cheapest way to go. Only downside is that you have to convert the sending unit to work with our trucks unless you're going with aftermarket gauges that are 0-90 ohms
Can't really comment on blazer tanks
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
Old 03-22-2011, 12:36 PM   #10
JeeperJoe
What year Camaro tank will fit and is there anyone else with photos that has done this install. I am lowering about 3.5 front and 5 in rear not going to be trying to set it in the grass. She is going to be a driver. I looked at your install K1, how did it work out?
Old 03-31-2011, 12:02 PM   #11
JeeperJoe
Front suspension parts installed..,,
Old 03-31-2011, 12:12 PM   #12
JeeperJoe
A little smoothing after welding in new panels.
Old 04-23-2011, 10:38 PM   #13
JeeperJoe
Starting on front end and setting engine and transmission to check for drive shaft length. Needs 4" taken off.
Old 04-24-2011, 05:44 PM   #14
tommys66
I used a 99' camaro tank. Had to trim the bottom frame rail on both sides about 1/2" I think. Used mounting straps from a escort. And I have a 5" drop in the rear.
I love the smell of lead paint!
tommys66 is offline   Reply With Quote
