View Poll Results: Poll Question¿
Clear? 0 0%
Can viewer help? 2 100.00%
Voters: 2. You may not vote on this poll
Old 03-18-2011, 05:42 AM   #1
ehcees
Question Gas Gauge & Sending Unit Remove/Test
1971 Chevy Cheyenne 10 Fleetside Long Bed, 2WD, 350/4bbl, AT.
Seeking instructions to remove & test:
(a) Dash gas gauge.
(b) Gas tank sending unit.
Diagrams would be plus.
Please do not use this thread for other topics or comment on text & color choices. Thanks.
ehcees is offline   Reply With Quote
Old 03-18-2011, 10:38 AM   #2
northerngmc
northerngmc's Avatar
Re: Gas Gauge & Sending Unit Remove/Test
Here is a link to a page that has a drawing and instructions for troubleshooting gas gauge problems.
http://www.6066gmcguy.org/Electrical-02.htm
Worked well for me on my 69 GMC a few years back.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 03-18-2011, 12:27 PM   #3
dmack91
dmack91's Avatar
Disconnect the sending unit wire. Ground it out and the gauge should move (to empty I believe) with the key on.
The resistance on the sending unit should read 0-90 ohms from the post to ground.
Just replaced mine and works fine now. Classic Chevy had the best price $30, that I found. LMC was $50.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
Last edited by dmack91; 03-18-2011 at 02:34 PM. Reason: corrected - thanks VetteVet
dmack91 is offline   Reply With Quote
Old 03-18-2011, 02:14 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The resistance on the gauge should read 0-90 ohms from the post to ground.
Yes the gauge should read empty if you ground the sender wire with the key on. Also if you unplug the sender wire from the fuse panel, the gauge should read full plus to the three o:clock position.
I believe you meant to say that the SENDING unit should read between 0 and 90 ohms depending on the float position.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-18-2011, 02:19 PM   #5
fixit-p
fixit-p's Avatar
Well the good tech has been covered but I have a question regarding the pole, what does it pertain to?
Edit>>> I mean poll.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 03-18-2011, 06:07 PM   #6
69sixpackbee
What "pole" ?? North, South or stripper?
69sixpackbee is offline   Reply With Quote
Old 03-18-2011, 06:11 PM   #7
fixit-p
fixit-p's Avatar
[QUOTE=69 1/2 Six Pack Bee;4561655]What "pole" ?? North, South or stripper?[/QUOTE
Hahaha, stripper pole would be nice.............I meant the Poll at the top of the thread (stupid spell check).
Old 03-18-2011, 06:12 PM   #8
northerngmc
So much for the request!
Pole or Poll?
To strip or not to strip, is that the question?
Blaine
Old 03-18-2011, 10:15 PM   #9
trapperjack
trapperjack's Avatar
Well this non-existant pole has helped me. I found it by by accident searching for gas gauge fixes. Poll, pole, or Pole, I don't care. I now know my sender is the problem, so thanks to all.
Back to your regularly scheduled pole, with no question.
1962 Chevy K10 factory 4x4 stepside longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=494632
1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded
1968 Chevy 1/2 ton panel wagon, V8 and powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=483345
1978 Ford F250, beater stepside
2008 Jeep Wrangler 4 Door
2010 Chevy 4x4 plain jane work truck
trapperjack is offline   Reply With Quote
gas gauge, sending unit
