Old 03-30-2011, 06:35 PM   #1
OJ1988
Just a car guy
OJ1988's Avatar
Longer wheel studs?
Anyone know where I can find longer wheel studs for the rear on my 69?
.472"knurl 7/16"-20
Stock length is 1.5" I need 2"
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 03-30-2011, 10:39 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Longer wheel studs?
napa
Go in with your info and they should be able to get them if they don't have them on hand
Old 03-31-2011, 09:27 AM   #3
cdowns
cdowns's Avatar
much better to take an old one with you the important part is to make sure the splined part is the same size
local autoparts store are a great source for common autorarts i prefer NAPA and CARQUEST as they normally have more knowelageble better trained(some even know how to read thru parts books) counter people
from what i see most 7/16 are .480
Old 03-31-2011, 10:52 AM   #4
rsavage
rsavage's Avatar
If I remember correctly, and there is always the possibility that I do not, I couldn't find longer stock 7/16" studs with that knurl a couple of years ago. I had put some 1/4" spacers on to bring the wheels out a little and wanted longer studs as I had only about 5-6 turns of the lug nuts. Never found them and removed the spacers.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 03-31-2011, 09:14 PM   #5
richierlb
most parts stores around my area carry dorman studs. try this part # 610-157 the catalog says they are 3/8" to 1/2" LONGER
1970 chevy c10 305/th350 3.73 open p/s vintage air
richierlb is offline   Reply With Quote
Old 04-01-2011, 12:09 AM   #6
OJ1988
Just a car guy
OJ1988's Avatar
Thanks for the leads guys.
From what I have found, there is not a longer version in .472. Some guys on camaro sites said they used the .480 studs with little problems installing.
The 610-187 appear to be .487
it's either longer studs or swap to 1" adapters.
1973 Vega Drag Car
1970 C20 tow rig
Old 05-07-2018, 08:58 PM   #7
w00dst0ck
w00dst0ck's Avatar
7 years old, but in case anyone is looking.
Moser makes a 7/16-20 .480 knurl. Part #8050
10x for $30 on amazon prime.
w00dst0ck is offline   Reply With Quote
Old 05-07-2018, 09:37 PM   #8
hotwls13
Just did mine last week on 70 gmc 1/2t. They are Dorman 610-186-1. About the same price at amazon or $2.50 each at autozone. They are approx 1/4” longer than the factory ones.
hotwls13 is offline   Reply With Quote
