Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-12-2011, 04:12 PM   #1
68project
Exclamation 1968 c10 4x4
Hey All,
I am new to the forum here and I am looking for a little help. What I have is a 1968 LWb 4x4 The truck was origanly a 2wd and was converted to a 4x4. It has a modified 350 and a saginaw 3 spd. Problem is that the 3 spd is not going to hold up. Alread having clutch problems linkage hanging up etc.. I need some recomendations for a good replacement transmission. Also original rear end is still in the truck. Not good for the 4x4 enthuiest. Need a few recomendiations for that as well.
Thanks for the help in advance.
68project is offline   Reply With Quote
Old 04-12-2011, 04:31 PM   #2
trapperjack
trapperjack's Avatar
Re: 1968 c10 4x4
Welcome, from a fellow Texan. Mine is a 67, should be same rear axle. They are pretty good, untill they aren't, then hard to get parts for. Post up some pics.
1962 Chevy K10 factory 4x4 stepside longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=494632
1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded
1968 Chevy 1/2 ton panel wagon, V8 and powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=483345
1978 Ford F250, beater stepside
2008 Jeep Wrangler 4 Door
2010 Chevy 4x4 plain jane work truck
trapperjack is offline   Reply With Quote
Old 06-10-2011, 07:01 PM   #3
hillbillydelux81
Re: 1968 c10 4x4
Is it a 1/2 ton or 3/4 ton? If its a 3/4 i would go with a 14 bolt rear. There strong and cheap.
hillbillydelux81 is offline   Reply With Quote
