Old 03-24-2003, 09:04 PM   #1
WHYBYNU
WHYBYNU when old will do
WHYBYNU's Avatar
Vac. line ?
I just pulled my gauge cluster out to put in a new oil gauge and I found a vac-line under the dash and it's not hooked to anything.
I follow it through the firewall and the other end is plugged into the left front vac port on the carb (1406 Edel.) What should the other end be plugged into?
Here is a pic of the line I'm talking about..
John
71 Cheyenne super
2 tone green and white
ZZ6 - Th350
4/6 drop
20x8.5 / 20x10 Billet Specialties
WHYBYNU is offline   Reply With Quote
Old 03-24-2003, 09:48 PM   #2
Blue Beard
Blue Beard's Avatar
Could go to a vacuum gauge that use to be installed.
Looks like you have A/C could be one of those lines..............
Where is it routed thru the firewall?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-24-2003, 10:05 PM   #3
WHYBYNU
WHYBYNU's Avatar
The truck never had a vac- gauge. The arrow points to the spot on the firewall where it runs through. I'm not real sure if it belongs in the cab or not . Anybody know where it should be hooked up?
thanks
john
71 Cheyenne super
ZZ6 - Th350
4/6 drop
Old 03-24-2003, 10:51 PM   #4
Class of 69
Class of 69's Avatar
The hose on my truck in that location connects the washer bottle to the pump under the dash
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 03-24-2003, 10:56 PM   #5
Blue Beard
Blue Beard's Avatar
That would be my other choice, my trucks torn apart now. but hard to see in the dark..............
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 03-24-2003, 11:57 PM   #6
WHYBYNU
WHYBYNU's Avatar
I guess I'll just take the hose off and put a nipple over the port on the carb, It's not hooked to anything anyway.
Thanks for the replies
John
71 Cheyenne super
ZZ6 - Th350
4/6 drop
