Old 03-24-2003, 10:40 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Unhappy Quadrajet
I am struggling like a big dog with the Quadrajet on my 72 GMC. The carb has stamped on it that it is made by Carter for Rochester. I put a kit in the carb (for models 4MC - 4MV) but it seems to me the accelerator pump is sticking in the bore. I get some gas coming up around the stem that comes through the top of the carb. This thing runs like crap and won't idle for squat. I tried matching the numbers on the carb with any number of websites to see if this is the right carb for the truck but I keep coming up with no match. The numbers are the carb are 6373S on one line and 898 on the second line. These numbers are stamped on the driver side just like what I see on the websites. I am guessing this is not the original carb; am I right? I have always run Holleys and Demons so I am a novice with the Quadrajet. I am beginning to understand why I hear alot of negative comments about these beasts. Any tricks to getting this thing acting properly would be greatly appreciated. Thanks for your help......
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 03-25-2003, 10:13 AM   #2
ckhd
ckhd's Avatar
If fuel is coming out of the top, there can only be three things wrong, either the float is not adjusted right, the float has a leak and 'sunk', or there is a piece of crud under the needle which won't let it stop the fuel flowing into the carb. Most likely a piece of crud, unless it was doing this before you did the rebuild.
The numbers you have are not the identification numbers. The right number will either start with 70 or 170. On the carbs made by Carter, some had the number on a metal tag... that someone probably lost before you ever got the carb.
There is nothing wrong with Q-jets. The people who complain about them just don't understand them and don't have them set up right. The ONLY thing I'd take over a Quadrajet is a good port injection system.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 03-25-2003, 10:27 AM   #3
Frank_Zeller
Frank_Zeller's Avatar
The top might be warped. Common on older q-jet. Make sure the vacuum break hold the secondary air flaps tightly closed at idle. (this prevents the bog) The U shaped wire that holds the float down should be bent up such that it hits the air horn a little. This insures that the float stays put and works correctly. Set the float to 1/4. Set the mixture screws out to 4 turns. Make sure you have the correct base gasket too. Flip carb over and check that its the right one. The q-jets use about 4 different types.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
