Old 05-01-2011, 04:40 PM   #1
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Ball Joint Adjusting Sleeve
Hello, all. I just replaced the ball joints on my '73 Chevrolet K20 with a Dana 44 front end. I did everything in the right order:
1) Tighten lower ball joint to 70 ft/lbs
2) Tighten upper ball joint adjusting sleeve to 50 ft/lbs (per GM specs)
3) Tighten upper ball joint castle nut to 100 ft/lbs.
When I tightened the adjusting sleeve on the upper ball joint stud to 50 ft/lbs, about 2 threads are visible under the axle "big C". Will this be an issue? Moog actually asks for the sleeve to be tightened to 70 ft/lbs, but I think that would have been overkill. When I removed the old adjusting sleeve, it sat flush in the big C.
I did everything per the Haynes, Chilton, and OEM assembly manual. The manuals call to check preload with a fish weighing scale, and it is supposed to be no more than 25 lbs of force when turning the spindles. It does feel more than that, but I'm assuming I have to allow for break-in.
I will post a how-to article with a lot of pictures in the near future. Thanks for all the advice.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 05-02-2011, 06:12 PM   #2
gcsupraman
gcsupraman's Avatar
Re: Ball Joint Adjusting Sleeve
Can't wait for the photos and "how to". Im ordering these tonight to fix caster issues on my truck
-Greg
gcsupraman is offline   Reply With Quote
Old 05-03-2011, 09:14 AM   #3
Burt4x4
Burt4x4's Avatar
First ~ Good job buying Moog! Great stuff!
Second ~ I don't recall everseeing threads. I haven't had a D44 in years but I did the same swap before and I just don't remember seeing them..Is it wrong? I don't know! You double checked your part numbers and all?
Put the tire on and see if you can rock in/out top/bottom. ANY movement is bad. If it doesn't rock...run it!
Good Luck
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 05-03-2011, 06:18 PM   #4
TheWhiteElephant
God is good!
Good Luck
Yeah, everything was done right. Those threads are from the adjusting sleeve, the one that is tightened into the axle housing with the spanner wrench, and not from the ball joint itself. I'm going to loosen everything up and re-tighten everything. I haven't greased them, either, so that may help. I'll post results.
Mando
Old 05-04-2011, 08:42 AM   #5
Burt4x4
Burt4x4's Avatar
Ya I know, I have the socket still hehehe. Well if ya pull um apart again I would check the threads and ensure thoes suckers are seatin all the way in..if so Run It! Ha!
Old 05-04-2011, 07:06 PM   #6
TheWhiteElephant
God is good!
You know, after I installed the bjoints the spindles felt pretty tight. A lot of threads floating around on the internet 4X4 forums with people complaining about the tightness of the Moogs and no one can figure it out.
Last night I got back out there and removed them and reinstalled them again (for a total of 3 times) and by gosh, I think I figured it out. They feel great now and in fact might feel a little too easy to turn, but I'll test them with a scale. I'll be sure to post a thread with the how-to pretty soon.
By the way, are you the same Burt from ColoradoK5? I think I remember you from back in the day when I had my Blazer.
Mando
Old 05-05-2011, 04:42 PM   #7
Burt4x4
Burt4x4's Avatar
Yup, That's me. My internet experiance began with CK5 back in '99ish. I think I found this place shortly after.
Old 06-26-2011, 09:06 AM   #8
Husker
Husker's Avatar
White elephant what did you find on this? I am getting ready to change mine out.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 06-27-2011, 11:19 PM   #9
TheWhiteElephant
God is good!
I got it all figured out. From my previous post:
"Last night I got back out there and removed them and reinstalled them again (for a total of 3 times) and by gosh, I think I figured it out. They feel great now and in fact might feel a little too easy to turn, but I'll test them with a scale. I'll be sure to post a thread with the how-to pretty soon."
If you want a detailed how-to, check out my build thread. I believe the trick is just to tighten, loosen, and re-tighten a few times. Mine feel great now. I never got to test them with a scale, but yesterday I managed to put most everything back together and drove it up and down the driveway, back and forth a few yards on the street, and all seems well.
If you need any help, I'd be happy to help, just shoot me a PM. It's a pretty straight forward operation.
Mando
Old 06-27-2011, 11:22 PM   #10
TheWhiteElephant
God is good!
Scroll towards the bottom here...
http://67-72chevytrucks.com/vboard/s...=430367&page=6
Mando
Old 06-28-2011, 02:51 PM   #11
Erik V
edit: because I didnt re-read which thread I was in.
Deleted all my pointless questions, sorry.
Erik
Erik V is offline   Reply With Quote
Old 06-28-2011, 09:30 PM   #12
TheWhiteElephant
God is good!
Erik
No prob, just answered your question in the other thread.
Mando
Old 07-01-2011, 11:11 PM   #13
Husker
Husker's Avatar
Nice build thread Elephant, Thanks for the tips.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
