Old 05-11-2011, 08:00 PM   #1
smorg007
smorg007's Avatar
Rear of truck not leval from left to right
My 1/2 ton SWB is lowered 4 1/2 (2 1/2 spindle & 2" coils) in front and 5 1/2" in rear with 4" drop coils and 1 1/2" lowering blocks. All springs are brand new. The truck sits approx 3/4" higher on the right (passenger side) than the left (drivers) side. It has the stock pan bar mounted in it's brackets and stock location. Could this be causing the issue? Do I need an adjustable pan bar to change the alignment of the rear. If so how do I do this. If I reduce the height of the passenger side lowering block by 3/4" and this levels the truck what issues am I creating if any. Thanks for you assistance.
smorg007 is offline   Reply With Quote
Old 05-11-2011, 08:18 PM   #2
cdowns
cdowns's Avatar
Re: Rear of truck not leval from left to right
it is not unusual for a 40year old work type vehicle to have a tweaked frame just about every chevy truck i've had have been lower like that on the drivers side
Old 05-11-2011, 08:29 PM   #3
leddzepp
Moderator
leddzepp's Avatar
agree 100%. both my trucks did/do the exact same thing
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 05-11-2011, 08:50 PM   #4
smorg007
smorg007's Avatar
So if I level it with by using different heights of the two lowering blocks I'll be okay and not cause or create any issues?
Old 05-11-2011, 09:01 PM   #5
leddzepp
Moderator
leddzepp's Avatar
I do not think it would cause an issue. I have contemplated doing it myself.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 05-11-2011, 09:44 PM   #6
VA72C10
VA72C10
VA72C10's Avatar
I'd try the panhard bar because with it 5 1/2" lower in the rear it's recommended anyways....
But I agree about the tweaked frame as a possibility...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-11-2011, 10:12 PM   #7
leddzepp
Moderator
leddzepp's Avatar
With a 5.5 rear drop, you do need an adjustable panhard bar to re-center the axle. I do not think it will correct your height difference, but it is still needed.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 05-11-2011, 10:56 PM   #8
67/72junkie
unhook your panard bar and see how it sits with it unhooked.Also try swapping the springs from one side to the other to double check and make sure the springs are keeping the same spring rate and height under load.Even new sometimes one will still be weaker than the other.
67/72junkie is offline   Reply With Quote
Old 05-11-2011, 10:59 PM   #9
edhtrd71
my 71 swb is also a 1/2 inch lower on the drivers side. I have a 2/4 drop and have been driving for a few years with a 1/2 inch lowering block on passenger side to make it look right with no issues other than embarressment when people ask me why. My bed will be coming off pretty soon and the truck is going on the frame machine to measure and adjust. I cant wait and hope it comes out right. Also agree you need an adjustable track bar and try to have it mounted completely flat at ride height.
edhtrd71 is offline   Reply With Quote
Old 05-11-2011, 11:09 PM   #10
smorg007
smorg007's Avatar
Thanks everyone for the input.
Old 05-11-2011, 11:13 PM   #11
leddzepp
Moderator
leddzepp's Avatar
This is also a good idea. I did this as well as flipping the springs top to bottom. In my case it was still the same and made no difference, but it is definitely worth a shot.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 05-11-2011, 11:19 PM   #12
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
it levels out when the fat lady gets in
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 05-11-2011, 11:56 PM   #13
RocketKing
RocketKing's Avatar
I was over 1/2" out on my 4/6 drop, turned out I had one of the springs in upside down. Switched it out and it leveled up.
Rex
RocketKing is offline   Reply With Quote
Old 05-12-2011, 03:17 AM   #14
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
The front can be problem too if the front springs are not in the top perch right this can cause the back to be off
screaminchevypickup is offline   Reply With Quote
Old 05-12-2011, 12:45 PM   #15
19seventeeCustom
^^^^Check this close, My truck was over 1" off from side to side, turned out the sprint wasn't seated over the upper perch causing it to sit unlevel.
19seventeeCustom is offline   Reply With Quote
Old 05-12-2011, 12:55 PM   #16
jhwkns
Registered Cruiser
jhwkns's Avatar
If it was mine, I'd have the frame straightened. It does wonders for an old truck. It did for mine.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 05-12-2011, 03:22 PM   #17
original-71
///Relaxed Atmosphere
original-71's Avatar
smorg mine is the same just under 3/4 difference not sure why either but then again i didnt measure before i dropped it 6 inches and with the adj pan bar. the wheels are even from fender to fender and the front is the equal height it puzzles me also. but then again i had a 98 S-10 that was one inch off had to use different blocks to make it right.
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R)
87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R)
hector
_________________________________
1971 Chevrolet Cheyenne Super
1987 Chevrolet Silverado
2006 Ford Mustang GT
2012 Toyota 4-Runner
2014 Dodge Ram 1500 Sport Crew Cab
original-71 is offline   Reply With Quote
Old 02-23-2024, 05:40 PM   #18
Myclassic68
I just put new -2 inch lowering springs on the front of my c10 and the passenger side sits 1/2” - 3/4” lower than the drivers side. I have checked the frame and it is not tweaked. Any ideas? I am new to these trucks so I don’t know all the tricks and fixes for this. All help is appreciated.
Myclassic68 is offline   Reply With Quote
Old 02-23-2024, 07:01 PM   #19
RustyPile
RustyPile's Avatar
Thanks for dragging out a 13 year old thread.. These old threads need to be aired out occasionally.
Totally ignoring everything previously posted, if I had the same problem you're having, I'd be checking the installation for properly installed and "seated" springs. If anything along these lines isn't found, try swapping the springs side to side.. If the low dimension remains the same side, you may have a tweaked frame or something going on in the rear. If the low dimension moves to the other side, you probably have one spring weaker than the other.
On another note, when lowering the front, suspension and steering geometry have to be maintained. For the first 2 - 3 inches of lowering, dropped spindles are a much better choice over shorter springs.
RustyPile is offline   Reply With Quote
Old 02-23-2024, 07:02 PM   #20
Sheepdip
Sheepdip's Avatar
That's correct It's also known as the "Bachelor Lean"
Sheepdip is online now   Reply With Quote
Old 02-23-2024, 09:59 PM   #21
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
My RH rocker is 3/8+" taller than the LH. That or vise versa, I don't care. But for the life of me I can't figure out why. Body lines are correct, body is square, level front to back and side to side (2.5" & 4" drop). Even the cab floor is level or close, can't remember. Cushions torqued the same, and frames are equal. Hmm.... Can't tell from anywhere short putting a measuring stick on each side.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 02-24-2024, 10:42 AM   #22
custom10nut
custom10nut's Avatar
That’s known as the “Chevrolet Gangsta Lean”
custom10nut is offline   Reply With Quote
