Old 05-20-2011, 11:23 AM   #1
Tod P
sway bar for '72 k1500
Has anyone tried using the factory front swaybar from a 73-87 on a 67-72? Are the spring perches the same width? Does the passenger side spring mount to the pumpkin the same on both series of trucks? Would there be an issue with the frame attachment points?
Tod P is offline   Reply With Quote
Old 05-20-2011, 09:38 PM   #2
dutchmanz
Knuckle Buster, Instructor
dutchmanz's Avatar
Re: sway bar for '72 k1500
Do a search, its been done and someone had good pics. I think you just swap the u bolt supports and front crossmember.
Current classic fleet:
72 K5 Blazer CST, unrestored factory Orange paint...mostly
69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration
53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue
dutchmanz is offline   Reply With Quote
Old 10-15-2011, 03:29 PM   #3
mo1968
mo1968's Avatar
check out texas firefighter very good write up, with part numbers and pics.
mo1968 is offline   Reply With Quote
Old 10-15-2011, 03:36 PM   #4
snj8198
snj8198's Avatar
hey Tod P,
http://67-72chevytrucks.com/vboard/s...d.php?t=487130
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
