Old 05-20-2011, 03:27 PM   #1
SactoJim
SactoJim's Avatar
Tie Rod Flip (to lessen bumpsteer)
I have "old school" stepped A-arms on my truck with stock spindles. Had this setup forever and it works fine except for the excessive bumpsteer. If I flip the tie rod on the spindle, the geometry will be much better.
Anyone here do this?....and if so, what's the easiest and most cost effective way?
I know DJM has a kit with drill, tap, and inserts for like $140 or so......not real interested in that route cuz I'll only do it once!
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 05-20-2011, 03:44 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Tie Rod Flip (to lessen bumpsteer)
I thought the same thing I'm in for the lesson!!
to bad we couldn't find a few trust worthy guys to go in on a kit ?? like you said your only going to use it once??
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 05-21-2011, 02:03 PM   #3
Scot_Douglas
Scot_Douglas's Avatar
You could try this:
tie rod inserts
All you need for this is 3/4" drill bit. I think the taper is the same as ours.
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 01-27-2013, 07:09 PM   #4
Luther Grimace
Luther Grimace's Avatar
Did anyone ever try this? I ordered a pair today. Hopefully they will fit my tie rods.
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540
1992 Chevy K1500 Silverado ECSB
1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered
Luther Grimace is offline   Reply With Quote
Old 01-27-2013, 10:38 PM   #5
FlammedC10
I am also interested knowing if these inserts will work because I too have "old school" stepped arms and would like to flip the tie rods.
FlammedC10 is offline   Reply With Quote
Old 04-12-2013, 12:11 PM   #6
Reyals Bemus
Hey Luther, did those inserts work out?
Reyals Bemus is offline   Reply With Quote
Old 01-08-2018, 05:23 PM   #7
Ben_Yeaton
Sorry to dig up an old thread, but I'm interested in finding if anyone has found a bushing that works with the C10 tie rod ends. I'm familiar with the press in bushing from the VW world; it's a common practice on lowered aircooled cars. They look this this:
The other options I see online are for Jeep applications and a Dana 30 option, but no specifics to the taper values or any measurements. Those look like they may work:
Maybe ordering a few different options and checking fitment would be worth it? Seems like this would be a very useful and cheap modification if the specifics can be ironed out. Thoughts?
Ben_Yeaton is offline   Reply With Quote
Old 01-08-2018, 10:36 PM   #8
hewittca
hewittca's Avatar
I’m in to see what others have to say as well. I will be flipping my tie rods but haven’t decided how I will do it yet. On my old bug I just drilled out the spindle from the opposite side with the correct tapered ream. It only left me with half the hole actually grabbing the tierod due to the hourglass hole in it, but it worked just fine. And yeah, it’s a common VW mod. I’m a little more hesitant to just do this on the truck, however, since it’s a tad heavier. Although, in researching it I saw a bunch of offroad Jeep guys doing this as well with no issues. I may give it a try and if I dont like it, I’ll weld up the hole and ream the whole thing out.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 01-09-2018, 08:21 AM   #9
PGSigns
PGSigns's Avatar
If you are running stock wheels you may want to do a quick check to see if the tie rod will clear the rim. Also there is the 73 and up tie rod end that is a bit bigger around and conversion sleeves are our there for the disc swaps. That would allow the taper to be deeper in the spindle for a better hold.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-09-2018, 09:01 AM   #10
hewittca
hewittca's Avatar
Jimmy
That's a great idea about swapping to the later tierod ends! If I don't like how mine look after reaming out for the stock tierods, I will definitely go this route.
Old 01-15-2018, 09:41 PM   #11
bdiamond
Could you have a machine shop slug the hole and redrill it the other way? I'm thinking drill the hole to a uniform diameter, machine a slug a few thousandths bigger so it'll be a press fit then redrill the taper on the other side.
bdiamond is offline   Reply With Quote
