Old 05-24-2011, 07:52 PM   #1
76/85 Truck
76/85 Truck's Avatar
Tranny Skips Second Gear!
Hey all! My truck skips 2nd gear when I put it in drive. It shifts right from 1st to 3rd. I have a TH-350 with a fresh filter and a fresh tranny flush.
I disconnected the kickdown cable because it was frayed and the frayed part would not allow the cable to return all the way, and it made my tranny permanently kicked down. I have the cable pushed all the way back as it will go...This worked for the past 2 months... Would this be causing the problem? It didn't do it until recently...
What would cause it to skip 2nd? If I put the gear selector in 2nd, it starts out in first and shifts into 2nd, just like normal. So, I know my 2nd gear is not shot. I can also manually shift or shift into drive once I hit about 35mph in 2nd.
What should I start looking for? The only time it skips 2nd gear is when I start out in drive, it will get to 15mph in 1st and shift straight into 3rd.
Thanks for everyone's help!!!
I appreciate it!
Rich
My first truck!! 1976 Chevy 3/4 ton Camper Special and a 1985 GMC body. Has a 350, 4 BBL Edelbrock, with a Turbo 350, and NP205 T-case.
76/85 Truck is offline   Reply With Quote
Old 05-25-2011, 01:05 AM   #2
76/85 Truck
Re: Tranny Skips Second Gear!
Bump
Anybody have any idea why it skips 2nd while in drive?
Thanks!
Rich
2nd, skips, tranny, turbo 350
