Old 05-31-2011, 07:41 AM   #1
Boknws
69 motor swap
Ok guys I need some input on swapping a 350 create motor for a 454! Is there any modification that I have to do with the mounts and the trans? Any information would be helpfull
Boknws is offline   Reply With Quote
Old 05-31-2011, 08:01 AM   #2
cheviss427
Re: 69 motor swap
Hello, I've done this swap and if memory serves me rite, the only part you will need are big block towers.
cheviss427 is offline   Reply With Quote
Old 05-31-2011, 11:08 AM   #3
ripdog28
ripdog28's Avatar
Re: 69 motor swap
Just the towers and all the mounting brackets (PS/WP/ALT) need to be BBC ones. If your using the same trans then youll be fine. If going from a TH350 to a 400 then you need to move the trans mount and cut the drive shaft 5/8 in.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 05-31-2011, 02:22 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 69 motor swap
The stock TH350 probably won't last very long behind a 454. Step up to that TH400.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-01-2011, 12:59 PM   #5
rblcori7
rblcori7's Avatar
Re: 69 motor swap
I have the exact same question. Im trying to do all my research before i jump into this. I have an 84 K10 with a 305 bolted to a 700R4 to the best of my knowledge i will just need to pull the small block motor mounts and bolt in the BBC mounts. I will also have to use the alternator, power steering, and starter from the BBC. what else will i need to do to the small block engine bay to stuff the 454 in it? any help will be greatly appreciated
84 Short bed 350: Hooker headers, flow master 40 series, edelbrock Intake manifold, Holly street avenger carb, 4 inch skyjacker suspension lift, 33x12.5 Toyo Open Country Mud Terrains, 3.73 gears
2011 Silverado LTZ
rblcori7 is offline   Reply With Quote
Old 06-01-2011, 11:58 PM   #6
Shyguy
Junior Member
Shyguy's Avatar
Re: 69 motor swap
You will probably need to figure out a different fan shroud than the one for the 305 and a 4 core radiator would probably be required to keep the 454 with the automatic cooled.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 06-02-2011, 01:13 AM   #7
rblcori7
rblcori7's Avatar
Re: 69 motor swap
If i do end up doing this swap it will be getting an alluminum radiator
2011 Silverado LTZ
Old 06-02-2011, 10:09 AM   #8
GASoline71
GASoline71's Avatar
Re: 69 motor swap
The 700R4 is just like the TH350 mentioned earlier. Probably won't last long with a 454 putting all that torque through it.
Gary
1969, 350, 454, engine, motor
