Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 06-04-2011, 11:56 AM   #1
NtheFamily
NtheFamily's Avatar
'92 return fuel line
On my 92 s10 the rubber portion of my return fuel line has sprung a leak (squirrels were thirsty). The dealerships have discontinued this part (lucky me) so can anyone tell me where I might be able to find one or how I might repair it?
I have tried several different junk yards, but no luck. The truck has the 4.3 v6 w/auto tranny and short wheel base.
This is the line that one of the rubber ends (rubber ends and hard line in between) hooks onto the fuel tank and the other end hooks onto another hard line under the cab.
Does anyone know how much pressure this line is under? Could I cut the rubber portion and clamp a pipe in between? Does anyone have one for sale?
Thanks for any input.
NtheFamily is offline   Reply With Quote
Old 06-06-2011, 05:41 PM   #2
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: '92 return fuel line
you could just get some 3/8 fuel line to replace it. There isn't enough pressure on a fuel system to blow the line's off if you have a good clamp. Just take a small peice of line to any auto parts store and get what you need.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 06-11-2011, 03:46 PM   #3
NtheFamily
NtheFamily's Avatar
Thanks for the info. That's what I have done and so far so good.
