Old 06-06-2011, 06:04 PM   #1
Low84
Low84's Avatar
"The Relapse" 78 Chevy Stepside
How's it going guys? I'm back with a 78 stepside I picked up yesterday afternoon. SOLID truck minimal rust, looking to get that fixed as soon as possible. I learned my lesson the first time around!
Anyway here it is:
1978 Chevrolet Stepside
250 cid Straight 6
3 Speed Manual Transmission (Death Trap)
The previous owner's last drive:
Right after it got parked in the driveway:
My partner in crime loves it
And after the Mavericks v Heat game this is what it looked like:
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 06-06-2011, 08:39 PM   #2
my4by2
my4by2's Avatar
Re: "The Relapse" 78 Chevy Stepside
Need a better shot of the wheels on it now since the first ones had the hub caps (which looked cool). Good looking truck man & looking forward to seeing where you take it!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 06-06-2011, 09:06 PM   #3
Chris Guthro
Amazing the difference since you changed the wheels!
Chris Guthro is offline   Reply With Quote
Old 06-06-2011, 10:38 PM   #4
Low84
Low84's Avatar
Thanks guys, I'll get some better pics of the rims tomorrow.
First thing on the list is getting the cab corner replaced.
Cowl induction hood
v8 swap
18" billet's
and we'll see how wild this one gets
Old 06-06-2011, 10:40 PM   #5
my4by2
my4by2's Avatar
Might I suggest an upgrade to an LS truck motor given you're looking to do a V8 swap anyway. You'll be MUCH happier with it, even it you run it with a carb it's still a better engine than ANY of the older V8 designs!!!
Old 06-06-2011, 10:43 PM   #6
Low84
Low84's Avatar
That's the plan. I initially wanted a crate engine ls1 but I'm in the process of buying some land and got to adjust the budget a little. Might go with a used 5.3 or 6.0.
I like the idea of running a carb on an lsx, I've heard the peak horsepower goes up but the fuel injection is stronger throughout the power band.
Old 06-06-2011, 10:48 PM   #7
my4by2
my4by2's Avatar
I originally purchased an '08 LY6 6.0L out of a 2500HD that had less than 10k on it, but started wanting a different cam & springs so I just ordered a new one from Mast Motorsports already the way I want & making 497HP at the crank. The shop building my truck is now selling that motor since I won't be using it - it doesn't have the ECM, pedal assembly or MAF sensor however (does have the wiring harness though).
I went with the LY6 due to the better head design over the older engines as well as the advantage of the VVT feature. Any of the truck motors are great though! Pace Performance has a 4.8L carbed LS motor that's complete from carb-to-pan for $3k which is a pretty good deal - especially for a light 1/2-ton truck!
Old 06-06-2011, 10:58 PM   #8
lilpoindexter
lilpoindexter's Avatar
WOW! You have great taste in trucks!
lilpoindexter is offline   Reply With Quote
Old 06-06-2011, 11:04 PM   #9
Low84
Low84's Avatar
That's not a bad price at all, but the truck racing scene is HUGE down here like you wouldn't believe. I wouldn't be able to do much damage, I need at least a 5.3.
That engine you have sounds like a straight up beast! I'm mainly worried about the wiring aspect of the swap, I'm borderline retarded with wiring
Old 06-06-2011, 11:08 PM   #10
Low84
Low84's Avatar
Just saw you avatar, haha! Thanks.
This was my old one.......err new one before cancer took over it:
Actually those are the rims I put on the 78
Old 06-06-2011, 11:08 PM   #11
my4by2
my4by2's Avatar
The Mast wiring & ECM is a little easier for installation & that's one reason I went with them. There are lots of companies though that sell LS harnesses that are pretty easy to install. Biggest thing is just ensuring adequate fuel flow & PSI.
Old 06-06-2011, 11:12 PM   #12
Low84
Low84's Avatar
Is this a complete setup? Just plug and play type of deal
Old 06-06-2011, 11:20 PM   #13
my4by2
my4by2's Avatar
Yep, for the most part - have to modify or change mounts, install the new pedal assembly & some other items, but pretty easy really. Mine didn't come with the fuel system (although you can get them) because we're using a new stock GM sending unit assembly for an '08 truck that fits in the gas tank they built. You can however just use the '87 sending unit assemblies in your tank & upgrade the pump.
Old 06-06-2011, 11:23 PM   #14
Low84
Low84's Avatar
Sounds simple enough. I'm going to start hounding around the junkyards for lsx engines right after i get that cab corner replaced
Old 06-09-2011, 12:35 AM   #15
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Nice score!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 06-12-2011, 05:27 PM   #16
Low84
Low84's Avatar
Thanks, it is I'm happy with it. It's getting tougher and tougher to find good, solid, build-able trucks for a realistic price.
Old 06-23-2011, 11:09 PM   #17
Low84
Low84's Avatar
Took me a little longer than I thought it would to get the pic, should have at least cleaned it
Old 06-25-2011, 05:16 PM   #18
notyo_cheez
Cool Re: "The Relapse" 78 Chevy Stepside
Nice. Subscriber from Corpus. Rust is a fact of life.
notyo_cheez is offline   Reply With Quote
Old 06-25-2011, 05:23 PM   #19
Pop's C-10
Pop's C-10's Avatar
looks good with those wheels on it..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 06-27-2011, 02:22 AM   #20
Low84
Low84's Avatar
Small world, I just got back from Corpus a few hours ago. Spent the weekend over there for the "Battle of the Bay" car show. Rust is the devil!!
Thanks, thinking of dropping it a little and cruising as is for the summer
Old 07-17-2011, 12:29 AM   #21
Low84
Low84's Avatar
Might be picking up a new engine for it tomorrow
Old 07-17-2011, 08:36 AM   #22
Chris Guthro
did you decide on 5.3 or 6.0?
Old 07-17-2011, 12:59 PM   #23
ghettoluxury
ghettoluxury's Avatar
What size are your wheels and backspacing?
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 07-17-2011, 01:06 PM   #24
Pop's C-10
Pop's C-10's Avatar
A 2in drop is all you'll get with those tires or you will rub tha fenders..do spring & shakles for now & when you need new tread..you can increase tha drop then..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Old 07-17-2011, 01:46 PM   #25
Low84
Low84's Avatar
If everything goes well today, it's going to be an lq4 6.0
They're 15x10, but I honestly don't know the backspace on them.
