Old 06-08-2011, 06:04 PM   #1
1krr
1/4 mile times with ls swap
What kind of times are yall running? post up engine/trans/rearend setup
im mostly curious about what type of rear suspension setup you guys run. just lowered, 4 link, trac bars ect.
im picking up a 84 shortbed with a 5.3/TH400/12 bolt has a 3800 stall and 3.73 gears. im excited to get into this project just curious what i can expect out of it.
1krr is offline   Reply With Quote
Old 06-08-2011, 10:09 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 1/4 mile times with ls swap
is the engine stock or modded, are you running DR's or street tires? Can you drive? There are alot of factors in terms of quarter mile times. Weight?
I know its not as helpful as posting a time (I haven't run my 66 yet), but you may get a WIDE variety. There are members into the 10's, but I'm sure there are some full weight trucks with stock 5.3's in the 15's.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-08-2011, 10:26 PM   #3
1krr
the one im picking up is a stock engine, full weight pickup. with what its got in it, i should be runnin 14s, which isnt even worth my time at the track haha ill be setting it up with a cam and spray, but all the hp in the world is useless without traction. even running slicks you are limited, if the truck does anything besides moving forward (i.e.squats, raises up in the rear) then you are losing forward momentum.
ive ran a multitude of vehicles down the 1/4, 04 gto runnin 11.90s and many many passes on my 08 1000rr running 9.40s.
i just like to do things once, i dont want to put trac bars on it when i should have 4 linked. rather do it right the first time so im looking to see what everyones setup is!
Old 06-08-2011, 10:34 PM   #4
Goats86
Got a bud with a 84 SWB with a 502 sprayed. He is very happy with his 9 inch Ford narrowed, setup with a 4 link and coil overs. We had to fine tune the coils a bit. Very sweet off the line
Goats86 is offline   Reply With Quote
Old 06-09-2011, 09:48 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
forgot your newer trucks were leaf spring'd, in that case you probably won't be happy with track bars only. 4 link isn't that hard to do if your not afraid of some fab, and the track is your main concern.
for a truck thats just a driver track bars would probably get you through tho.
Old 06-09-2011, 09:49 AM   #6
Shon
not 1/4 but on a set of 26" DRs mine went 8.8 @ 80 1/8th mile and 7.8s @ 88 on 100shot.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 06-09-2011, 02:24 PM   #7
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
haven't run it yet.... due to trans leaks
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-09-2011, 09:05 PM   #8
Super73
Super73's Avatar
Did you check out the racing section on this web page? There is even a link called suspension 101 that I started and never finished that has some helpful info on how to get these things too hook. There are also a lot of knowledgable guys in that section that might have a little input for you.
My old times are in my sig, that's with a 347 cubed motor, a 4L80E, 4.56's and a 30" drag radial.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 06-10-2011, 01:59 AM   #9
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Well mine has some restrictive headers and y pipe as well as a bad hot air intake thats sucking in hot radiator air, as well as a really rich tune. Anyways it easily ran a 13.5 @ 100. I'm almost 100% sure its got 12's in it with a tune and some other stuff. For suspension its the stock 69 coil spring 12 bolt rear end setup 3.73 gears with a posi. Engine build is in my sig.
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 06-10-2011, 01:24 PM   #10
68GMCCustom
...and you know I'll be gunning for you and your trucks times!
Kurt -
Old 06-16-2013, 03:37 PM   #11
Blackpony
Blackpony's Avatar
Thread revival!!! Haha
Took my 85 to the track last nite. With pretty much a stock 5.7 ls engine with cai and exhaust it ran a 14.6 at 98 mph. I am running the stock open diff with 3.08 gears so my short time sucked. Looking to swap a set of 3.42 gears with a LSD unit soon. Should aid in my times...
Blackpony is offline   Reply With Quote
Old 06-18-2013, 12:14 PM   #12
Super73
Super73's Avatar
I would be surprised if the gear change gives you much off your ET. A good tire and posi will help for sure. Once you do that, a converter would really wake it up.
Old 06-18-2013, 10:41 PM   #13
Blackpony
Blackpony's Avatar
yeah i have a 2500 stall in it now, looking at the powertrax locker units seems they are pretty good units.
Old 06-18-2013, 11:20 PM   #14
BigDan3131
BigDan3131's Avatar
Just remember to figure in your tire height when selecting your gears. Tall tires make it seem like you have less gear and shorter tires make it seem like more.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 06-19-2013, 12:19 PM   #15
Wasted Income
Boosted Member
Wasted Income's Avatar
A 2500 rpm stall might as well be stock, especially if it's stock diameter.
My 3400 9.5" Yank still feels really tight. Your truck would be a lot of fun with a 3600-3800 stall.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 06-19-2013, 03:16 PM   #16
68GMCCustom
My billet 258mm/10.25" CircleD convertor was ordered as a 3000-3200rpm stall, and wound up roughly 2800rpm actual. I hear this is common. I am considering having it restalled (1free 1st yr) to 3200-3500rpm or so depending on how things go when I finally get it to the track. My d/r's are 30" tall but may get replaced w/28's.
Kurt -
Old 06-20-2013, 12:13 AM   #17
Blackpony
Blackpony's Avatar
No the stall speed is just fine for what I plan to do with the truck. I was digging through the tune today as I was having a problem at the track with the truck falling off around the 100 ft, so i did a heavy log all the way through 2md and found that I missed changing the speed limiter, so the truck was hitting the 98 mph limiter just a tick before the 1000 ft and just holding.. haha noob mistake on my part. now its fixed might hit the track again before the summer is over and see how it does... planning a locker soon so that will help a lot.
Old 06-20-2013, 07:31 AM   #18
68Stepbed
68Stepbed's Avatar
Cammed LS1 with 750 Holley carb, 700R4 with 2800 stall and 4.11 gears. 29" rock hard street tires(for now). Truck weight is under 3600lbs before my fat butt gets in. Stock suspemsion lowered 4.5/5.75 with ECE springs/spindles. In the video above, I spun through first gear, it shifted into second while spinning, spun most of the way through second gear before finally getting traction, crossing the line with the engine spinning close to max rpm in third gear. Even with all that, it ran a 14.15 at 97.98mph. I believe low 13's is very possible if I can hook and manually shift it. Those were just fun runs on Power Tour, so I just put it in drive(not OD) and let the trans do what it does.
My engine seems to make TONS of power at lower speeds but tends to weaken at high speeds, which indicates the fuel system isn't keeping up. I don't spend much time in the upper rpm ranges at high speeds, so I'm not too concerned with that for now. I do plan to eventually tune the carb with an A/F ratio gauge.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 06-20-2013, 09:34 AM   #19
Wasted Income
Boosted Member
5.3L, factory ECU tuned by me with EFI Live, 317 heads (wouldn't do again...WAY too lazy out of boost), LS6 cam, Borg Warner S471 turbo, non-intercooled, water/meth, 60 lb injectors, Bosch 044 pump, 3.73 posi rear, 4L80E, Yank 3400, 275/60/15 MT Drag Radials, 4230 race weight...oh and it was lifting the heads....lol. I didn't care about cutting a good reaction time...just wanted to beat my buddy in the yellow dodge. Still had vacuum brakes at the time, so it would push thru the brakes and I couldn't build ANY boost on the footbrake = super lazy from a dig.
11.95 @115 was my fastest on this combo.
Turbo diesel
Old 06-20-2013, 03:41 PM   #20
Super73
Super73's Avatar
Just a little food for thought for some of you regarding gears vs converter.
First running made roughly 410rwhp through a locked 3,200 rpm converter + 26" drag radial + 3.73 gear + 3,900lbs = best of 1.89 60' and ran 12.3x
Next time out made 420-430rwhp through a locked 4,500rpm converter + 30" ET street +3.73 gears + 3750lbs = best 60' 1.67 and ran 11.96 was still in 2nd through the traps.
Next time out made 449rwhp through the same locked 4,500 converter + 30" drag radials + 4.56 gears + 3,650lbs = best 1.67 60' and ran 11.578
In my case, gears almost seemed negligible but noticed it pulled a couple degrees of timing on the hit. Took it back one last time with the old combo.
Everything the same as last time but race weight 3,525 and no timing being pulled on the hit = 1.60 60' and 11.45.
Old 06-20-2013, 08:18 PM   #21
Blackpony
Blackpony's Avatar
I pull a trailer often so in my case gears are almost a must. My truck is not nor will not ever be a track queen maybe 2-3 times a year will it see a track. So with that being said a huge converter will kill everything I am trying to accomplish with my truck which is 20+ mpg drive it anywhere in pure comfort but still have power to enjoy it when I want. Thus far that has been accomplished for the most part but there is plenty to be desired when it comes to pulling a trailer loaded. My ac blows cold, truck runs great, gets around 22 mpg last time I averaged it and is very reliable. I would be willing to bet a set of 3.42 over my 3.08 gears will help my mileage. Most of my driving consist of going from 65 mph to a dead stop then back to 65 mph about 15 times on my way to work. So taking off from the lights having a little more gear to get the truck moving I doubt will hurt. My mustang went from 17-18 mpg average with the stock 3.08 to 21-22 mpg average with 3.73 gears and would get 26-27 mpg straight hwy before and after the gears. Our shop car I helped build runs 5.20's at 135 mph and cuts 1.2 60 ft times in the 1/8 on 275 drag radials so I have a pretty good idea how to go fast in a straight line.
Old 06-20-2013, 11:06 PM   #22
Super73
Super73's Avatar
Put an 80e in it and use the lock up while towing. I agree you shouldn't go 4,000-5,000 with the verter but 3,200-3,600 with a short 1-2 shift and an almost instant 2nd lock up. If you use a truck PCM, you can program the tow/haul feature to do something like that. Just food for thought.
Old 06-23-2013, 10:05 PM   #23
Blackpony
Blackpony's Avatar
I already have a nicely built 4l60 in it. Everything is fine with it, except I am fighting with the converter lockup. Any time it drops below 20% tps it will unlock. I have set it to where it "should" command it to lockup 2 mph after 4th gear shift and stay in lockup unless it sees 0% tps and it still unlocks. I cannot figure it out, I've had 3 different tuners look at the tune and nothing changes it. I have verified wiring, all the electronics are brand new and verified to be working properly. I am at a loss... As it sits, the truck tows just fine cruising and from a take off, I just figure a little better gear will help with a take off. Mostly I need some sort of locker or limited slip as right now one wheel peels suck.. haha I have a unit from a 70's camaro just having a hard time dishing out $300 for axles plus gears, bearings, and the parts to freshen up the unit..
Old 06-24-2013, 12:31 PM   #24
Super73
Super73's Avatar
What year pcm? What did it come out of?
I can try and find a file in Hptuners repository and see if I see anything that would cause that.
I am assuming you don't have hptuners and the ability to send me your current file.
Old 06-24-2013, 12:54 PM   #25
Blackpony
Blackpony's Avatar
No i am using efilive to tune with. I can send it to you if you want to download the software, it will allow you to view it but not change it. The ecm is from an 05 3/4 4x4 truck.
