Old 06-12-2011, 07:04 PM   #1
Shane
Shane's Avatar
"squeaky" leaf springs
Got an issue that I've not run across before, the leaf springs on my '05 GMC have started "squeaking" as of late. Tried experimenting with a bit of white lithium grease on the spring mounts/shackles with very little luck. I've owned at least 5 trucks with leafs in the rear and this is the first time I've had this issue. I'm scratching my head.
advice? thoughts? suggestions?
Shane is offline   Reply With Quote
Old 06-12-2011, 08:35 PM   #2
Psycho71
Psycho71's Avatar
Re: "squeaky" leaf springs
My 98 used to do that on the front and rear suspension components. I used a liberal amount of white lithium on all of the rubber stuff and it would take a few days to work into the parts, then it would last a month or so. I drive down a lot of white rock roads though, so it kinda comes with the territory.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 06-12-2011, 10:05 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Are they stock bushing? You know the problems associated with urethane bushings, but I have not heard of this with stockers.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-12-2011, 11:12 PM   #4
Shane
Shane's Avatar
they are stock on the front hanger and McGaughey's shackles in the rear - unsure what they put in their shackles ... but the weird part is the squeaking seems to be coming from BOTH ends.
Old 06-13-2011, 11:25 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
I'll bet the McGaughys are urethane. Sounds like your going to need some Polyurethane lube
Articles-
"Refining Sierra"
