Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 06-21-2011, 03:55 PM   #1
Rednek13x
Rednek13x's Avatar
I need tips on removing thick grease from engine.
So i got this 57 with the inline 6 and its caked with old grease and what not. I would really like to clean it up so no grease and crap in the engine bay area. I know how to clean light dirt and stuff in a engine bay with the simple green like spray.
But how would i go about getting this thick crap off? Am i going to hurt anything?
Rednek13x is offline   Reply With Quote
Old 06-21-2011, 08:12 PM   #2
Sillyoldman
#16876
Sillyoldman's Avatar
Re: I need tips on removing thick grease from engine.
Scrape & spray where you can and brush where you can't. I would also like to know of a better way. Steam?
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 06-21-2011, 09:11 PM   #3
Rednek13x
Rednek13x's Avatar
Well i worked on it a little tonight. First power washed everything as much as i could. That really really helped and got A LOT of the big thick stuff off. Then i dried it all day and sprayed on some walmart engine de greaser and let sit for a few minutes. Power washed it all again. Im to the point now were its pretty clean. There is still some hard grease that will need to be scraped off. I found break cleaner to work pretty dang good for the scrapping and brushing.
Old 06-21-2011, 09:26 PM   #4
Sillyoldman
#16876
Oh wow it's green! Looks tons better.
Old 06-21-2011, 09:30 PM   #5
Rednek13x
Rednek13x's Avatar
Ill keep picking slowly away at the grime with my fingernail and toothbrush.
Old 06-22-2011, 01:17 AM   #6
treveiger
treveiger's Avatar
I've heard a heated pressure washer works great also. We have one but never used the heat part lol.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 06-22-2011, 08:21 PM   #7
imdarren
imdarren's Avatar
Oven cleaner melts away stuff like that like MAGIC!
You just have to be careful not to get it on your skin or eyes. And if you do, wash it off right away.
You have to be careful because it is so strong it will strip paint and start to rust right away all in one step. It can mess up aluminum too if you leave it on too long. So use caution.
If you don't want paint stripped, don't use it, just use multiple applications of degreaser. Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 06-22-2011, 10:23 PM   #8
treveiger
treveiger's Avatar
You can use oven cleaner but wear a mask an gloves an also glasses wouldn't be a bad idea. That stuff is nasty an if breathed in will mess you up. Used some a over a week ago for my motor and tranny an still have a sore throat.
Old 06-24-2011, 01:48 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Marine Clean by POR. It is like simple green x 1000.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 06-24-2011, 07:13 PM   #10
Rednek13x
Rednek13x's Avatar
Will that stuff affect paint/gaskets or harm anything?
Old 06-25-2011, 12:44 PM   #11
leddzepp
Moderator
leddzepp's Avatar
I have not had a problem with it. I would try to avoid getting it on areas that don't need it.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 06-28-2011, 11:14 PM   #12
yote1234
yote1234's Avatar
i have heard diesel fuel is a good cleaner and wont take paint...?
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 06-29-2011, 08:04 PM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
I've used just degreaser's in a can
but after high school i did pressure washing for a couple of years
drove a 5ton with water onboard and the washer system
i'd do greasy tanker trucks and the heat would peel the oily dirt off
sometimes leaving clean streaks if you got too close but the fifth wheel hitches would have to be spotless after for safety inspection
for sure heat works,you can find it at the bottom of your ho****er tank or you can plumb it to your outside tap,use regular shut offs from each line to a y ,then outside,if it gets frosty you need to drain both in the winter
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-29-2011, 08:08 PM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
also pressure washer drive in bays use hot water here
John
Old 07-01-2012, 12:24 AM   #15
primrrd
primrrd's Avatar
diesel is a decent degreaser- i restored a few tractors that had a lot of real estate mixed with oil and grease stuck to it--- initial cleaning involved a few soakings with diesel- it loosened it up and made it easier to chip away later.... looks like you are making good progress on the clean up!
- and yes, even if you just are using a brush and soapy water, hot water always works better.
motornut,
it took me a few minutes to figure out why the filter wouldn't let you type about your ho****er heater. made me laugh
primrrd is offline   Reply With Quote
Old 07-01-2012, 11:12 AM   #16
cdowns
cdowns's Avatar
diesel and kerosene are favorites of mine, have been using for quite a few years// it is cheap and easy on both the skin and the object that is being cleaned
Old 07-03-2012, 05:18 PM   #17
motornut
78K & 79C Jimmys
motornut's Avatar
motornut,
lol yup had a good laugh at that too,after i figured it out
John
Old 07-05-2012, 04:08 PM   #18
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice work on that engine bay.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-15-2012, 03:08 PM   #19
jhaymon
jhaymon's Avatar
remember you hot water heater has a tap to hook up a water hose. that combined with a pressure washer does a magnificent job
is it done yet?
jhaymon is offline   Reply With Quote
Old 01-31-2016, 02:39 AM   #20
rod1701
rod1701's Avatar
For the fire wall, if there isn't caked on grease, and.just the regular dust, dirt and road grime, I have found that us a spray on rinse off wheel cleaner will cut it well.
Also working on the Suburban engine bay, not sure it has been cleaned in 45 years. Honestly .other sure.if the engine has ever been out of the truck. Even the drivers side heat shield was still on the manifold. Will have to.take a pic a d show what was attached to passengers side manifold.at the flange, looked.like.a.valve or baffle.of.some sort.
Anyway, Started with Purple.Power, not a dent. Moved to POR, very little difference. Then to $1 oven cleaner and cut most of it off. Then pulled brackets, manifolds, pulleys and accessories and.found tons more goop.Hit it again with oven cleaner, while keeping exhaust ports plugged. Going to check again tomorrow. I.think another light oven cleaner.and.maybe brake.spray cleaner.Dr before painting.
1979 C-10 LWB
rod1701 is offline   Reply With Quote
