![]() ![]() Join Date: Jan 2011
Boss 338 / Coys C5 wheel question
This may have been posted / answered before but I am curious before I make my wheel selection.
My truck is a 69, but it has had the 73-87 front swap. I have heard people mention the Coys and Boss wheels do not fit the 67-72 trucks exactly right (the center bore problem) Would I have the same problem running 73-87 front end? Do you know if the Eagle 225 has the same problem? Also, what's a good backspacing to run on the front? My truck will have about 4.5" drop, (2.5" spindle, one turn cut out of the coils .. PO cut them)running 20x8 or maybe 20x8.5 if I can get away with it. What are you guys running on the front? 5.5" bs? 5" ? what works best? Tire size? Pics? Thanks.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
Laid Back
![]() Join Date: Apr 2010
Re: Boss 338 / Coys C5 wheel question
on the front of my truck im running 20x8 coys with a 5.25 back space and on if they will fit it just depends on if you have light duty or heavy duty rotors most light duty rotors you will have no problem with but you can run a spacer behind the cap
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
Laid Back
also the front of my truck is lowered 5.5 with no rubbing problems at all
![]() Join Date: Mar 2011
im all over this thread ! in one month im ordering the c-5 wheels and im intrested to know what others have experienced with them . im so hard up for pics of yalls coys wheels id almost pay to see them !
Master Procrastinator
running 20x8.5 338's, cheap wheels to buy and the machining on the rotors cost me $40, pretty minor and could have been ground at home with a common grinder and patience, lots of pics in my build thread probably the last page or 2 just got the front rolling but here are 3 to give you the idea, this was not all machined to fit just to match the factory taper on the rotor, all you need is the top 1/4inch or so needs to be ground for them to fit. The general consensus is the coys are far better quality but the customer service is awful, to me you get what you pay for, my 338's look really good but the caps don't fit too easy I wrecked 2 being rammy, I'm cheap so the 338 was my only option. Truck is just a chassis but I'm running 2.5 western drop spindles and 3 in cpp drop springs out front 7 in drop rear and plan on a 2.5in spacer out back
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project Last edited by tantrumpipeline; 06-23-2011 at 07:29 PM. |
![]() Join Date: Jun 2011
I'm running 338's. 20 x 8.5 fronts, and 20 x 10 rears. They fit fine.
Boss fixed the clearance problem. I just put these on this last weekend. No clearance issues at all and they look awsome!!! |
what backspacing/offset are your Boss wheels Manxxman??
BTW, nice ride! Is it bagged? or just one hell of a static drop? |
#8 | |
Boss only offers 1 backspace for the 8.5 wide rims. I beleive it's 5.75" and the 10's have a 6.25 i think. Yes it's bagged, but it is going lower by the time i am done with it. Thanks for the nice comments. |
Laid Back
heres my coys the truck is 5.5 front 8 back front wheels are 5.25 bs and the rears are 5 bs the look and work great i thought the customer service was great ordered the wheels on a monday had them by thursday even know im not keeping these wheels on this truck i would highly suggest them to anyone
#10 | |
![]() Join Date: Dec 2006
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
![]() Join Date: Jan 2002
Hey screaminchevy
On the black chevy with coys. What size tires are you running and is it the stock 71-72 rearend??? Thanks
55 Chevy original swb (big back window) 61 Chevy bubble top (427-5 speed) 67 Chevy stepside (Krusty) 68 Chevy swb fleet (Lola) 68 Chevy swb fleet 71 Chevy swb fleet ( future PB project) 97 crew cab power stroke 07 SS Trail blazer |
motor exploder
I'm running a 73-87 style front end on my '69 with the Boss 338's. I have CPP '73-87 2.5" drop spindles, CPP tubular arms and 2" springs. I have 73-87 1.25" rotors and had to turn them down so the front wheel would seat on the rotor all the way. I'm running 18x8's in front with 4.5" bs, 245/40/18's. 18x12's rear with 7.5" bs, 335/30/18's and will end up running a 1/2" spacer in the rear to even out the track width since I'm running my original 69 rear which is narrower than the 71-72 rears. Look for project 'Silver Dollar' in the builds section, he's running 18's also and has a complete truck to look at, mine is only a chassis at this point.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#13 |
Some pics of my rolling chassis for you. I have the McGaughys 13" Disc brake conversion kit that uses a smaller hub so I had no problems with my Coys, they bolted right up.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 Last edited by Bennett68C10; 06-24-2011 at 06:51 AM. |
#14 |
18"x8 front 18x 9.5 rear, 4.5/6' drop no rub or spacers
#15 |
18 x 8 fron , & 20 x 8.5 rear, had these a couple of years, got them when they 1st hit the market and had to make spacers for the center caps. I understand they have fixed this issue since then
#16 |
///Relaxed Atmosphere
CC69RAT go with the COYS C-5, IMO.
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
#17 | |
Who me?
Living the dream ![]() 72 2WD Blazer, under going porter built surgery 67 GT Mustang fastback 67 Mustang coupe C/S clone 64 Falcon sprint hardtop |
#18 |
motor exploder
needless to say, they're not stock, they were originally 9.5" wide... Contact James @ weldcraftwheels.com
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 06-24-2011 at 02:56 PM. |
#19 | |
Laid Back
#20 |
Laid Back
The only thing that I don't like about the boss wheels is the offsets the front stick out more than the rears and the back sits way to far in without running a spacer
#21 |
my blazer is running 20x8 and 20x10 c5's.tires are 235-35 and 275-35...bolt right on and have no clearance issues
#22 | |
Laid Back
#23 |
motor exploder
Looks awesome - love the stance and color!
#24 |
Here is my 72 truck sold a while back with 20x8.5s and 20x10s. 255-45s and 275-45s. About a 4/6 drop. 2.5 spindles with one coil cut. and 5 rear coils and 1-1.5 blocks??? Front tires were to tall, rubbed on dips in road etc.
Boss wheels are worth the time since they are cheap. I want coys still. I didnt like the rear boss wheels because there wasnt much of lip due to the 6.25 B/S. I had a 1 inch adapter to make it work. Less than a 100.00 bucks. EZ adapters. I think?? I had less than $1400.00 in everything. Worked for me because i was selling truck. But i am going to order Coys this week, unless i cant afford my first choice. I also want a 295-40-20s. Hope they fit with no mods to bed. It seems to work for some people.
55 Chevy original swb (big back window) 61 Chevy bubble top (427-5 speed) 67 Chevy stepside (Krusty) 68 Chevy swb fleet (Lola) 68 Chevy swb fleet 71 Chevy swb fleet ( future PB project) 97 crew cab power stroke 07 SS Trail blazer Last edited by STP67-72; 07-14-2011 at 09:36 PM. Reason: error |
#25 |
Man of Mini-Talents
These are Coys C-5's 18X8 with 4 bs 255/45-18, 18X9 with 5.5bs 295/45-18
The truck is dropped 3.5/5. The second pic shows the spacer. You can buy them from a forum member (pm me - he's not a board vendor) mde of aluminum, or Coys will send you some plastic ones.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
