Old 06-29-2011, 02:06 AM   #1
eightyfive
eightyfive's Avatar
Fender bender and grille question
Yo, So i had a little bit of a mishap the other day while gettin pulled out of a mud hole and my grille and passenger fender got a little banged up.
My question is, will a grill from a '95 or newer bolt up to my '88 rad support? Im just gunna rip one off my moms boyfriends old trucks and bolt it up if it all works out.
parts truck- 1982 suburban GMC Sierra Classic
first project- 1985 GMC Sierra Classic
first truck- 1988 GMC Sierra sle
"New" Hot rod 1999 Chevy silverado 5.3L
Workin my way up the food chain
eightyfive is offline   Reply With Quote
Old 06-29-2011, 12:22 PM   #2
benoit454
Chris
benoit454's Avatar
Re: Fender bender and grille question
from what I have seen yes perfectly, HOWEVER you need the lower grille filler and the 2 end pieces as well as the 2 inner bumper brackets to make it work without cutting and hacking or leaving things off.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 06-29-2011, 02:43 PM   #3
kieth
kieth's Avatar
too bad you are not closer, I have a 88 gmc 3/4 burb that you could come and get the fender off of. Kieth Tulsa, OK
kieth is offline   Reply With Quote
Old 06-29-2011, 08:40 PM   #4
dbcox
dbcox's Avatar
You need to get the headlights buckets and plugs for the healights. they will bolt right up. You do need that filler piece under it. Im tried to make mine work ,but i need a newer lower piece. I got the grill out of a 98 tahoe.. You will need to cut out some small spots for the taller headlight adjusters...Iposted a pic of mine on here about a week ago to give you an idea
www.lubedealer.com/dbcox
ZO#1568374
dbcox is offline   Reply With Quote
Old 06-29-2011, 11:34 PM   #5
benoit454
Chris
benoit454's Avatar
88 burb and blazer is still the suqare body style like 81-87 trucks, 88-98 trucks are gmt400 style.
I was assuming he has a gmt400 style vehicle.
Chris
GIT R DONE!!!!!!
bolt on, grill, grille
