Old 07-11-2011, 02:20 PM   #1
corysam
A/C blows hot and cold
truckers,
i have a 1991 Chevy 1500 SWB. When i leave the house in the morning, the A/C works fine. It continues to work until the 1st time i kill the truck. when i retsart it, the A/C bows hot air. It usually stays that way until the next day but sometimes, it will start working again during the day. Also sometimes it will be blowing cold and then just start blowing hot air aga
in. When it starts to blow hot air, the compressor is still running. If i turn off the air, you can hear the compressor kick off and the idle change so the compressor seems to be working. I added freon about a month ago but it didnt seem to be low then. Is this a switch or something? any ideas?
thanks
corysam is offline   Reply With Quote
Old 07-11-2011, 02:57 PM   #2
jay55jay
Re: A/C blows hot and cold
That sounds like the blend door is failing. 91 I think has a digital Control panel. I had that happen to me.
jay55jay is offline   Reply With Quote
Old 07-11-2011, 06:16 PM   #3
corysam
ah the blend door. so whats the fix? new blend door? I'll look into it. any tips?
thanks jay55jay
Old 07-11-2011, 06:24 PM   #4
jay55jay
I know they can be a pain to get to depending on the truck. If you can get to it when it's in the Cold position unplug it for Summer. then switch it for Winter. Some applications requires to take the Dash out if its all compacted in there..
Old 07-11-2011, 06:32 PM   #5
corysam
thanks
i've been to youtube and there a lot of videos on fixing this. thanks for pointing me in the right direction.
Old 07-12-2011, 05:56 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Here's something for you....
Member Nr. 2770
air conditioner
