Closed Thread
Old 07-13-2011, 01:15 AM   #1
tll74
"Junkyard Dog"
tll74's Avatar
100's of misc parts from the last 6 trucks parted out
Hi guys, I have sorted out a bunch of parts from the last 6 trucks I have parted out. Al parts are cleaned and ready to ship. . Shipping on small items will be via USPS and larger-heavy items will be via UPS. I will respond to all post in the evening as I have a 8-5 daytime job. I'm on the west coast so I'm 2-3 hours behind many of you. Combined shipping no problem. Please reply in the thread.
Thanks, Tom
Please list what you are paying for rather it be Paypal or a mailed check.
Pic 1
Visors 20.00 each Black and one pair of olive green are Sold
inside mirrors: 71 olive green better than average glass 23.00 SOLD, 69-70 brown and black average glass 17.50
72 LH armrest needs painted DQ 10.00 SOLD
67-68 armrest 17.50
2-72 olive green armrest 17.50 each Sold
3-70 olive green armrest 17.50 each
70 olive green seat belts 2 pass 95.00 very nice Sold
68? green (turquoise?) 3 pass 125.00 very nice on hold, the wife thinks she wants them for her 68
Glove box doors 1 green 69 GMC, 1 brown 70 GMC, and 1 green Chev 22.00 ea
2 67-70 front - rear (first connection) brake lines nice cond 25.00 ea. plus sh.
3 ashtrays all green 12.50
Dome lens housing with wiring (was chrome) 12.00
2 67-70 GMC horn buttons 9.00 each
head liner retainers tan from 70 GMC with gold interior 7.50
5 headlamp switches with plain and chrome knobs 10.00 each
6 wiper switches with plain and chrome knobs 7.50 each
cigarette lighter 7.50
Pic 2
2 RH outside door handles DQ 15.00 each
2 LH outside door handles DQ 17.50 each SOLD
10 inside door handles 7.50 each
6 window cranks 7.50 each
71-72 turn lens housing nice 17.50
1 back up lens nice 7.50 each
3 tail lamp lens nice 12.50 each Sold
cargo lens, housing (pitted) and rubber 15.00 Sold
cargo lens, housing (nice), rubber, switch and wiring (not in pic) 60.00
white mirrors off 1970, ding in housing, glass DQ has light scratches 50.00
5 original front amber marker lens good color 6.50 each
1 original rear red marker lens good color 6.50
2 rear deluxe red marker lens good color 8.50 each Sold
2 front deluxe amber marker lens faded 6.00 each Sold
4 GMC turn lens-housing good color 15.00 each
5 horns 10.00 each
dome lens and white housing 12.50SOLD
dome lens and chrome housing (chrome gone) 8.50
5 wiper arms with original blades 12.50 each
4 wiper arms without blades 10.00 each
1970 350 point distributor 25.00
4 e-brake cable from cab to frame 18.00 each (only one in pic)
cab vent 6.00
washer res. cap w/hose 4.00
spark plug heat shield set- acid dipped and rust free 27.50SOLD
3 windshield washer hose sets complete 12.50 each
Pic 3
Fender emblems:
2 GMC 1500 V8 8.00 each
2 GMC 2500 V8 8.00 each
2 GMC 2500 custom camper 8.00 each
2 67-68 chev 20 8.00 each SOLD
69-up custom/10 10.00
1 pair K/5Blazer 40.00SOLD
1 pair Custom/20 27.50 (I hot tanked these and the black is gone)
1 pair Sierra Grande 75.00 nice, no studs
1 pair Custom good studs 11.00
8-350 7.50
deluxe 5.00
2 tail gate center moldings 12.50 eachSOLD
4 E-brake cables with all supports LWB only 27.50 each
4 oil pressure lines for sbc 10.00
4 GMC turn/park lamp wire looms 6.00 each
2 ground straps (valve cover-firewall) 3.00 each
2 vent pull rods w/knobs media blasted 4.50 eachSOLD
RH GMC eyebrow minor ding nice driver 15.00
LH GMC eyebrow ding lower corner DQ 15.00
2 69-72 sbc alt brackets complete w/bolts 29.50 each
69-72 sbc upper alt adjustment bracket 15.00
2 67-70 throttle mech. w/ 2wd-Q-jet rod 22.50 each
67-70 gas pedal 7.50
2 69-72 steering column intermediate shafts 27.50 each
2 lower metal steering column bezels 5.00 each
2 lower dash pedal stop brackets 6.00 each
67-68 2wd LH exhaust manifold original GM nice condition 65.00
67-72 2wd RH exhaust manifold used aftermarket plugged A.I.R. holes 50.00
69-72 sbc 2 groove water pump pulley 13.00SOLD
67-72 sbc single groove crank pulley 11.00SOLD
sbc LH exhaust gasket sleeve 5.00
sbc RH exhaust gasket sleeve 5.00
RH 71-72 headlamp bezel DQ minor sand pit 12.00
LH 71-72 headlamp bezel DQ small ding-sand pit 9.00
67-72 GMC RH chrome headlamp bezel nice 17.50
70 green dash bezel only chrome in typical cond. Sold
Pic 4
4 69-72 7 blade flex fans 23.00 each
70 1/2T Bendix power brake booster assy w/prop. valve 75.00SOLD
71-72 3/4T Moraine dual diaphragm booster assy w/prop. valve 85.00
3 original antenna's 2 telescoping and 1 single mass (newer mast) 33.00 ea. One tele. antenna (w/o spring) SOLD
set of door edge guards very nice DQ 25.00
71-72 gas pedal w/cable 27.50 SOLD
3 taillamp wiring harness's for lwb (from cab to bumper) 15.00 each one sold 2 remaining
More to come.
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline
Old 07-13-2011, 01:41 AM   #2
botmfedr1
botmfedr1's Avatar
Re: 100's of misc parts from the last 6 trucks parted out
ill take the spark plug heat shield set in pic 2, a set of windshield washer hose set, washer res cap w/ hose, 2 vent pull rods, and your best taillamp lwb wiring harness, and a telescoping antenna
please send me your paypal info....
thanks
mondo
botmfedr1 is offline
Old 07-13-2011, 01:45 AM   #3
70LonghornCST
Moderator
70LonghornCST's Avatar
Do you have a ball bearing ashtray with a nice inside? If so, I'll take it.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline
Old 07-13-2011, 02:08 AM   #4
tll74
"Junkyard Dog"
tll74's Avatar
pic 5
72 Blazer LH sun visor kinda ruff has good mount 20.00
72 Blazer RH sun visor kinda ruff has good mount 20.00
Blazer only door latch reinforcement RH and LH 25.00SOLD
Blazer fuel filler cover some dings 22.00SOLD
Blazer fuel vent tube some dings 15.00SOLD
Blazer rear gate hinges a bit loose 22.00
Blazer rear gate supports 40.00
Blazer front top mount brackets 12.50SOLD
pic 6
67-72 windsheild rubber with all stainless moldings, very nice condition 75.00 plus shipping.SOLD
pic 7
2 inner heater housing assembly 35.00 plus shipping.
pic 8
2wd automatic cross member 40.00 plus shipping.
firewall side heater housing faded but in excellent cond. 35.00 plus shipping.
72 only fuel line from tank to frame 19.00
pic9
70 C10 RH lower control arm hot tanked 30.00 plus shipping.SOLD
70 C10 LH lower control arm hot tanked 30.00 plus shipping.SOLD
70 C10 RH upper control arm 25.00 plus shipping.SOLD
70 C10 LH upper control arm 25.00 plus shipping.SOLD
70 C10 front springs with 350 AT 30.00 plus shipping.
67-70 LH steering arm 19.00
67-70 RH steering arm 19.00
more to come
tll74 is offline
Old 07-13-2011, 02:10 AM   #5
IndyRich
IndyRich's Avatar
Closer picture/ condition of the GMC 1500 emblems? Thanks
IndyRich is offline
Old 07-13-2011, 02:41 AM   #6
Juarez823
Do you have any fan shrouds? Also looking for a 67 wiring harness auto for gauges.
Juarez823 is offline
Old 07-13-2011, 02:42 AM   #7
jimmyballpeen
jimmyballpeen's Avatar
I will take the K5 blazer fender emblems
jimmyballpeen is offline
Old 07-13-2011, 02:49 AM   #8
Juarez823
I will take a cig lighter, wiper switch and light switch! Is there anyway I can pick them up in person? I live in Corvallis
Old 07-13-2011, 02:59 AM   #9
tll74
"Junkyard Dog"
tll74's Avatar
I'll look! thanks
tll74 is offline
Old 07-13-2011, 03:01 AM   #10
tll74
"Junkyard Dog"
tll74's Avatar
No problem I'm 4 miles south of Junction City on 99. Thanks, Tom
tll74 is offline
Old 07-13-2011, 03:04 AM   #11
Juarez823
PM your phone # I will give you a call tomorrow to pick them up! I dont know if you read my earlier post but do you have a fan shroud or a wiring harness for 67?
Old 07-13-2011, 03:12 AM   #12
tll74
"Junkyard Dog"
tll74's Avatar
Will do.
tll74 is offline
Old 07-13-2011, 06:34 AM   #13
72 tigger
72 tigger's Avatar
I'll take (2) b/up lens (need a LH & RH), (2) taillight lens,both center tailgate mldgs. (if they're nice- no pits), & a LH &RH outer door handle set (if they're not to rough- pits, etc.) Please PM me your info- thanks!
72 tigger is offline
Old 07-13-2011, 06:52 AM   #14
Leroy-B1
interested in turquoise seat belts, nicest antenna you have available, 67-68 turquoise arm rest, and nicest pair of exterior door handles you have...please PM with package deal price, bought the green dash from you a while back
Leroy-B1 is offline
Old 07-13-2011, 08:47 AM   #15
creepdogg
Pic 4, are those underdash wire harnesses? If so what condition?
creepdogg is offline
Old 07-13-2011, 08:57 AM   #16
kellytheaker
hi tom i will take a tl harness if it is intermediate, firewall to TL. and the nice cargo lite housing and of course the other items - antennae ect
kellytheaker is offline
Old 07-13-2011, 05:42 PM   #17
m6z
m6z's Avatar
Do you happen to have a clutch delete plate for the firewall or a choke delete for the inst. bezel?
Doug
Looking for a 67-72 short bed driver.....
m6z is offline
Old 07-14-2011, 12:14 AM   #18
68Mike
68Mike's Avatar
I'm also interested if you have an underdash harness for 69-72 non ac with gauges
Mike
Currents:
'74 Cheyenne Super C30 Camper Special 3+3
aka "Sucia30"
Past:
'79 C10 BIG 10 (Sold)
69 CST LWB - Always a "Work in progress" true work truck (stolen)
05 GSXR 750 it has a pretty paint job _wrecked
72 SWB full frame restoration -sold!
71 CST K5 Blazer 4x4 (soon to be 2wd)-project - sold!
C10 Club 2012 Brothers Show Video
http://youtu.be/pUeV2vP7Wpo
68Mike is offline
Old 07-14-2011, 01:51 AM   #19
tll74
"Junkyard Dog"
tll74's Avatar
70LonghornCST, I do have the ashtray with the ball bearing sliders. The inside is decent but used. I could media blast it if desired.
IndyRich, pics as requested. There is some pits. They should clean up to be very nice driver quality.
Juarez823, I have big block and 2wd small block shrouds. bb 65.00 plus and sb 40.00 plus. 67 under dash wiring for gauges and AT trans 75.00 shipped.
72 tigger, I'll verify your concerns in the morning.
Leroy-B1, 72 tigger is up first on the nicest outer door handles. I have 9 trucks waiting to be parted so I'm sure I can take care of both of you. The tele. antenna with the spring would the nicest one available. PM sent
creepdog, the wirings are out of a 70 and 72 C10 350, AT w/ gauges. 75.00 shipped per harness. Let know your needs as I have many more.
m6z, Yes on the clutch delete. No on the choke (wike took it for her truck)7.50 with the screws shipped.
68Mike, no problem 75.00 shipped, nice harness.
tll74 is offline
Old 07-14-2011, 02:30 AM   #20
Juarez823
Is the condition good? Also, to make a dash w/ gauges work do I have to replace the engine harness too, or just the underdash?
Old 07-14-2011, 02:37 AM   #21
70LonghornCST
Moderator
Do you think the inside will be free of pits if blasted? If so, I'll take it. LMK. And PM me payment info.
2018 Chevy Crew Cab
2006 Impala SS
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
Old 07-14-2011, 04:27 AM   #22
68Mike
68Mike's Avatar
How clean is it? Are there any cuts in it?
Mike
Currents:
aka "Sucia30"
Past:
68Mike is offline
Old 07-14-2011, 07:51 AM   #23
67gmcstepside
I'll take what ever set is available or which ever is in better condition if they are still available.
Thank you, Don
67gmcstepside is offline
Old 07-14-2011, 08:37 AM   #24
Sarge
I'll take the water pump double pulley and the single grrove crank pulley...also need non A/C heater control if you have it. Thanks, going to 13135 please
Sarge is offline
Old 07-14-2011, 08:42 AM   #25
m6z
m6z's Avatar
I'll take the clutch delete. Pm me payment info.
Thankss,
Doug
m6z is offline
Closed Thread
