Old 08-14-2011, 10:57 PM   #1
KAC
KAC's Avatar
TH350 Transmission Help!
WHAT'S Up Everyone!
Well, its been a while since I've been on here (been busy with work)... I finally have time and a little bit extra $ to work on my '85.
Heres the question/what I did....
My Transmission was leaking from the pan, so this weekend I went to O'Rileys and got the new gasket and a gallon of transmission fluid. I took off the pan and let it drain (Friday Night). I went to put on the new gasket and it happend to be the wrong one. So today I went back to the store with my transmission pan and got the correct gasket.
I put on the new gasket and put in about 3.5 quarts of the transmission fluid and let it settle in. I went to put it in drive and NOTHING!!
The truck drove before I changed that gasket.... (when I found out it was low on fluid all I did was add 2 Quarts of ATF, and by the next day it had leaked out)
Right now I am unable to check to see if there is enough fluid because the tip of the dip stick was broken inside the tube close to the pan.
So I guess my question would be:
How much fluid is actually needed in an TH350?
OR
Do I have bigger problems?....
1974 Chevy Shortbed Stepside
1985 Chevy SWB <--- My Donor Truck
1991 Ford F-150
2007 Pontiac G6 GT
2008 Dodge Grand Caravan
My Photo Album
'74 Round Eye Stepside Project
KAC is offline   Reply With Quote
Old 08-15-2011, 08:40 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: TH350 Transmission Help!
i would remove the the houseing bolt holding the tube
slide the tube out/up from under the truck
try and remove it to measure it
to hard to guess how much is in there......converter holds a lot
not enough it won't work,but to much is bad too
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 08-17-2011, 12:35 AM   #3
KAC
KAC's Avatar
Thanks for Responding Motornut,
I got it to work now...
Yesterday I stopped by a local salvage yard and picked up a dipstick and a coolant overflow cap for the truck. I checked the level and sure enough it was low... added another quart.
So looks like the amount of ATF needed is about 4.5 - 5 Quarts.
I was able to drive the truck around the block a few times so its all good now....
1991 Ford F-150
2007 Pontiac G6 GT
My Photo Album
th350, transmission, transmission fluid
