want to buy clutch fan 3883158
anyone have a clutch fan part # 3883158. pics of one below. interested in new or used.
Re: want to buy clutch fan 3883158
some info on the clutch...
65-66 Ser. 10 thru 30 w/Air Cond., H.D. Rad. (327) (2nd design), 66 Ser. 10-20 4/WD (250), 67-68 G-10,20 w/P.G. (6 cyl.), 67 G-10, 20 (8 cyl.), 67-68 Ser. 10 thru 30 w/C.A.C., H.D. cooling (292), 67-68 Ser. 10 thru 30 w/C.A.C., H.D. cooling (8 cyl.) (exc. 4/WD), 67-68 Ser. 10-20 (4/WD) w/C.A.C., H.D. cooling (327) ................. (7 1/8" dia.).......................... 3883158 |
![]() Join Date: Aug 2008
what type of fan blade are yiu using is it part number 3883159
I am using fan 3955182. It is a 18" seven blade. This will be going in a 67. i know the clutch is the same part # but am unsure f the fan will be the same. I found 1 clutch on the 67-72 classifieds so i no longer need this.
i think the blade is a 5 blade for part number 3883159 that fits on 3883158 clutch i am trying to find one blade to see what they look like
here is a pic of fan 3883159
Thank you for the picture does the fan have any part numbers stamped in it thanks mike
