Old 08-31-2011, 04:46 PM   #1
60apache
60apache's Avatar
frame modification
so my truck is a 1960 so I have the x frame. my question is has anyone modified their frame to run exhaust or even cut the x out?
60apache is offline   Reply With Quote
Old 09-02-2011, 05:45 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: frame modification
modifying the frame to fit the exhaust? Um....modify the exhaust to fit the frame usually works better. The older big body gm's had x frames in the early years, they manage to squeeze some decent pipes into.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-06-2011, 09:40 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
Are you set on running the exhaust on the inner side of frame rails?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 09-12-2011, 12:57 AM   #4
60apache
60apache's Avatar
well the exhaust now is outside the frame but I would like to do an x-pipe or both into one 3"
Old 09-12-2011, 05:32 PM   #5
vin63
vin63's Avatar
It can be done, but it will require a significant portion of the exhaust to hang below the frame. Is there a particular reason you want an X-pipe?
Old 09-23-2011, 07:49 PM   #6
60apache
60apache's Avatar
better flow and better sound on ls1
Old 09-23-2011, 07:58 PM   #7
66redw/white
made in america
66redw/white's Avatar
is there any room to go between the frame and the body?
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes.
sounds good
1964 c10-283 powerpack, 3 on the tree
2004 corvette- lowered, borla, tuned. slow
my old girl
1966 c10- 305v8, t-5 sold
66redw/white is offline   Reply With Quote
Old 09-23-2011, 09:04 PM   #8
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
my 50 chev convertible "X frame" has windows cut in the x on the drivers side for the factory single exhaust... years ago someone cut matching windows on the other side.
another method that I saw on a super low 57 caddy: the exhaust was intergal, and welded into the frame rails, exhaust flex tubing was used in between the manifolds and the front part of the exhaust
Old 10-12-2011, 12:00 AM   #9
60apache
60apache's Avatar
thats a good idea.
Old 10-12-2011, 12:58 AM   #10
72bigred
I am doing a 60 also.. I have went over this in my head a thousand times. I do have a 60 frame that has the X cut out that someone installed a cross member with holes for exhaust and it appears solid.. I saved it.. for whatever reason I dont want to get rid of it.. I although stayed with the X probably because "its different" than what most do and I tend to be that way. I am going with an inline 6 and I am keeping the torsion front susp.. I have no other way than to drop between the torsion and run outside the frame on one side. I did see this summer a guy that had cut half moons out of his X to allow for exhaust. The way I see these frames built unless you are planning on pulling the front end off the ground in the 1/8 or 1/4 they are strong enough to take the half moon cut and it can be done very clean.. I will check my pics as I took many of what he had done, it was clean and neat and looked great. Not sure what HP he was running but it was tubbed and built.. I saw no other extra added support from his mods to the X..
72bigred is offline   Reply With Quote
Old 10-12-2011, 08:59 AM   #11
vin63
vin63's Avatar
The X-pipe doesn't provide better flow...it does quiet down the exhaust (which is the primary goal with X-pipes on from the factory since the cross pulses help attenuate noise at lower RPMs) - if that's what you're looking to achieve. Being part of lots of exhaust research (flowbench, CFD modeling and real world) when I worked at Banks Engineering and the X-pipes' scavenging effects don't really occur until the upper RPMs, the range varied according to tubing diameter and distance from the collector.Just my $0.02 if it helps with routing your exhaust.
Old 10-12-2011, 02:49 PM   #12
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: frame modification
Check me out Bud.
Think I am the only one in the pack!
I cut the X part out.
Boxed & relieved frame as well.
ROJECT: "FULL METAL YELLOW JACKET Build Thread (Page 5)
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 10-12-2011, 04:04 PM   #13
1Bad62Pro/Street
Homemade exhaust
Mufflers made out of 3 1/2" OD steel driveshaft.
http://www.hotrodhotline.com/md/asse...iveshaft-4.JPG
I thought I had pictures of the mufflers. Looked all over.
I'll have to take a picture of them.
https://skydrive.live.com/?cid=9169A...1365&sc=photos
