Old 04-10-2003, 03:37 PM   #1
48Pickup
A few ?????
I just started working on my 48 Chevy pickup. I was wondering if anyone knows which rearends would be pretty easy swap. I'm putting a 350/th350 in it. Also any ideas about gas tank and brake booster/master cylinder. Thanks for your help.
48Pickup is offline   Reply With Quote
Old 04-10-2003, 07:04 PM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Rear end from a Nova size frame is only 1/2" wider. For a master cylinder some have used 69 Mustang. You will probably get more results by going to www.stovebolt.com there are a lot of us AD fans there.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-10-2003, 07:31 PM   #3
Ed ke6bnl
Can you use this 69 mustang m/c if you still have alldrum brakes all around or was the 69 all drum and does it make a differance. Ed ke6bnl So. Calif
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 04-14-2003, 10:41 AM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Check with a parts store, but I think it was a drum/drum setup.
Fred
