Old 09-12-2011, 06:31 PM   #1
Mrtn15
Mrtn15's Avatar
I need help with speedo cable
I recenty got my th350 trans rebuilt, now my speedo cable doesnt work.. theres a screw holding a metal plate down where the speedo cable cant screw down all of teh way, but whe I take the metal plate and screw out, the speedo cable doesnt screw on, the whole assembly or whatever turns.
1986 Single cab 2WD Chevy 350/350
1977 Single cab Dually C30 BB454!
Mrtn15 is offline   Reply With Quote
Old 09-12-2011, 06:32 PM   #2
Mrtn15
Mrtn15's Avatar
Re: I need help with speedo cable
Old 09-12-2011, 06:45 PM   #3
Pyrotechnic
Pyrotechnic's Avatar
Check and see if the gear is in there, maybe it got left out?
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 09-12-2011, 06:50 PM   #4
Mrtn15
Mrtn15's Avatar
What is the gear ? I have no knowlege on any of this "speedo cable" jazz lol
Old 09-13-2011, 10:01 PM   #5
raceman6135
Dino burner
raceman6135's Avatar
Here is a picture of the speedometer gear "bullet" and the driven speedometer gear assembled:
It's possible that this gear (below) was left out when the transmission was rebuilt:
raceman6135 is offline   Reply With Quote
Old 09-14-2011, 10:29 AM   #6
Mrtn15
Mrtn15's Avatar
Oh! I guess I will take It to the transmission shop, and let then take a look! Thanks guys! I was hoping this was something I could fix myself
Old 09-14-2011, 10:42 AM   #7
Your41Plague12
Your41Plague12's Avatar
You can fix it yourself, it takes 5 minutes to see if it's there or not. Undo the speedo cable from the tranny, wind out the "bullet," and see if the plastic gear is there. If not, just order one from online. They're less than $20 if I remember right. But if it's the transmission shop's fault, I agree, they should guarantee their work and fix it in a timely fashion if they're respectable at all.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 09-14-2011, 10:00 PM   #8
jdheff1982
I have a related q, is there a seal/gasket that is meant to prevent tranny oil from leaking at the speedo cable? I always see red fluid pooled around it.
Thanks.
Project and Truck Specs: http://67-72chevytrucks.com/vboard/s...d.php?t=483381
jdheff1982 is offline   Reply With Quote
Old 09-14-2011, 11:41 PM   #9
meter swinger
meter swinger's Avatar
When mine quit workin i just cut it off...but i wouldnt recommend it. now im gonna have ti fix right. If you gotta buy one there cheap n easy to find. Maybe thats why i like these trucks. Cheap-n-easy
meter swinger is offline   Reply With Quote
Old 01-09-2012, 03:24 PM   #10
sleepchamber
sleepchamber's Avatar
And all that Jazz!
1985 Scottsdale 305/350
sleepchamber is offline   Reply With Quote
chevy truck, help me please, speedo cable
