09-14-2011, 12:43 PM | #1 |
Under Dash Mounted Master Cylinder??
Anyone have one of these setups on their truck? (specifically 47-53)
http://www.hotrodandrestoration.com/...el-komponents/ Looks like a good idea, filling would be a challenge, but probably no worse than an under cab one without a hole in the cab floor. Have not found a direct kit for our trucks, anyone know of one? Didnt see one the CCP website but found this tech article on 55 and up: http://www.classicperform.com/tech_a.../GotBrakes.htm |
09-14-2011, 12:50 PM | #2 |
Re: Under Dash Mounted Master Cylinder??
No experience with it, but gotta say I sorta like it.
But I do think you might have more issues with it behind the dash than on the frame rail under the floor. All kinds of crap in the way, like the cowl vent (if applicable), defrost ducting, and wipers, just to name a few. |
09-14-2011, 01:10 PM | #3 |
i was considering the kugel stuff for an under-dash power disk setup on a 66 C10 so I could leave a dummy single pot master under the hood. BUT, at the time, was wishin I had an AD truck so I could just stuff a kit under the floor and call it a day.
Since there are several mfgrs that make under cab power dual masters, why not just use the under the floor approach? There are proven kits by CPP, etc, specifically for this. Interesting - in the end, I decided to not go under the dash due to space limitations (in my 66) |
09-14-2011, 04:23 PM | #4 |
Plan is to run true duel exhaust and the master may get in the way/be near heat if under the cab.
Dont want it in the firewall, plan to do a smooth firewall. Looks like a neat concept, hoping someone chimes in that has done one and what the experience was like. Besides the things mentioned, wiring for the gauges and what not also is behind the dash. |
09-14-2011, 07:20 PM | #5 |
Hydroboost is your friend.
09-14-2011, 08:03 PM | #6 |
09-14-2011, 11:45 PM | #7 |
I have one. They work great. I fill it with a squeeze ketchup bottom with a tube on the on the of it.
Look at the ones from scotts hotrods. They make the best ones with bushings and whatnot. The kugel ones are just a bolt in a tube. |
09-15-2011, 12:00 AM | #8 |
I used a kit from ECI but had to modify it a bit, moved it back out of the way of everything, used the stock brake arm and hole in the toe board
Both of these chassis are 53 AD and ECI brake kits
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
09-15-2011, 12:08 PM | #9 |
The under the dash kit is the same idea I had as I will also be running true dual exhaust and the truck will be air ride. So I will have have very limited space under the cab and between the frame rail. I had not seen this kit but I know Summit Racing has a similar kit that I was looking at.
09-15-2011, 12:13 PM | #10 | |
Thanks |
09-15-2011, 12:30 PM | #11 |
If I was running that setup I would want to install it first and then build the truck (underdash part) around it.
With my creaky old joints I can't flex around enough to service it anymore so it would be out for me but it might be great for younger guys who are able to work up under the dash. I was thinking about running a hydro boost and moving the master cylinder back further similar to what Solidaxle showed. |
09-20-2011, 10:13 AM | #12 |
check this out.
http://67-72chevytrucks.com/vboard/s...=302780&page=1 I ran a dual diaphragm 7" I think with a vette master. |
09-22-2011, 04:46 PM | #13 |
Thanks Cajundragger for filling the guys in regarding our underdash pedal assembly.. Since we are a supporting Vendor you know we'll take car of you guys! Not only do we have the pedal assemblies instock but we are also the manufacture! If you have any questions please feel free and ask.
Installed under a C-10 dash |
09-22-2011, 04:50 PM | #14 |
Do you sell it as a complete assembly with booster and master?
If so how much $$? |
09-22-2011, 05:17 PM | #15 |
Forum Member price is 360.00 complete with master/booster , our pedal assembly is complete with the brake mounting pad (we don't charge an additional 20.00 for like some) we use bronze bushings, and our assembly is 100% TIG Welded
we also offer remote fill reservoirs the dual machine finish is 110.00 pol. add 20.00 and the master lid is going to run 50.00 with the seal |
09-22-2011, 05:27 PM | #16 |
Cool, looks to be about $100 less then the Kugel one.
09-22-2011, 06:26 PM | #17 |
09-23-2011, 12:07 PM | #18 |
If only money grew on trees. Still trying ot get out of debt from the engine I bought and then save up for frame boxing plates....
09-23-2011, 12:51 PM | #19 |
Is it so that the remote resevoirs must be mounted higher than the master cylinder (logically)? If so, where could you mount one? I've seen some very pretty ones, NO LIMIT has a great polished one, but where to mount one thats higher than the M/C?
09-23-2011, 01:40 PM | #20 |
our polished remote reservoirs are 130.00 retail and are typically mounted on the firewall when doing a underdash or frame mount assembly
09-23-2011, 02:08 PM | #21 |
Hey Jon, I'm considering a set up like this for my 59. Do you guys have any pics of installs on a task force truck?
Do you know if I would have to remove the instrument panel to dash brace assembly? Is there still a chance of still fitting a heater defroster or even an a/c unit with the MC under the dash? |
09-23-2011, 04:15 PM | #22 |
Let me check our photo archive and see if I can dig up any photos.... I personally have no experiance on installing them on your truck but I will ask Justin or have him chime in, in a few
10-10-2011, 06:48 PM | #23 |
'57 Rosa
Jon, I am interested in the same concerns as hotrodrookie except I have a '57. Please let us know about space for a/c and intrument panel. I am going with a dacota digital unit. Thanks.
My '57 Truck Build "Rosa" (Current Project) http://67-72chevytrucks.com/vboard/s...21#post4118721 2003 Dodge Dakota 4X4 (Daily Driver) Only two defining forces have ever died for us: CHRIST died for our salvation and VETERANS died for our freedoms. Glorify CHRIST and thank VETERANs Dru~ USN Retired |
01-09-2012, 02:50 PM | #24 |
Project collector
I know this thread is a couple months old but has anyone used one of these setups in a 67-72? I'm interested on one for Jezebel but need to make sure it does not have clearance issues. It looks to me like it may be very close to the wiper motor or where I plan to install the Vintage Air Evap.
Anyone? Perhaps someone from Scottshotrods can chime in. Thanks, Steve
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel Jezebel 3.0 NEW!!! 2020 GMC 3500 Denali Duramax 2016 Harley Street Glide CVO Roll Tide! |
01-09-2012, 02:53 PM | #25 |
I have the same questions, not sure yet if I am going to put AC in the truck but would be interested to know if anyone has this setup with AC and what issues they ran into if any.
