Old 09-17-2011, 02:10 AM   #1
rayfinseats
edelbrock vs quadrajet carb
Edelbrock vs quadrajet carb on off-road 4x4. Any opinions? Anyone noticed a difference in power? I noticed the edelbrock is easy to tune and work on but my experience with the quadrajets so far I'm not real impressed with the edelbrock c600cfm carb . It doesn't seem to accelerate as good as a quadrajet and seems to suck lots of fuel but I haven't tried a quadrajet on this vehicle yet. I've already had the primary air bleeds plug up twice and tonight it flooded for no reason all of the sudden after working fine for a couple months.
rayfinseats is offline   Reply With Quote
Old 09-17-2011, 10:21 AM   #2
turp mcspray
turp mcspray's Avatar
Re: edelbrock vs quadrajet carb
For off road, bouncy, off camber, type driving, the edelbrock is the WORST, and the quadrajet is the BEST. As long as the fuel curve is correct, power will be the same. The engine doesn't know what kind of a carb is feeding it.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 09-18-2011, 12:26 AM   #3
Zoomad75
K5Camper
Zoomad75's Avatar
Q-jet is by far better. I've never had a problem with mine. Back in the days when DirtyLarry still had a carb on his beast he was running an edlebrock with the off-road kit. His truck compared to mine ran completely different when we got up to higher altitudes and odd angles in the mountains. His was always loading up running rich at low speeds and stalling at the wrong time. Mine putted along without any fiddling other than a slight bump in timing to run a little better at the higher altitude, no loading up, coughing or stalling even at odd angles.
Larry might chime in but I know it annoyed him to no end and was a giant deciding factor to switch to running fuel injection in some form.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 09-18-2011, 05:27 PM   #4
Alderson95
quadrajet
Alderson95 is offline   Reply With Quote
Old 09-18-2011, 05:54 PM   #5
desertrat
desertrat's Avatar
Originally Posted by turp mcspray View Post
For off road, bouncy, off camber, type driving, the edelbrock is the WORST.......
What he said!
"Men are like steel. When they lose their temper, they lose their worth." — Chuck Norris
desertrat is offline   Reply With Quote
Old 09-20-2011, 08:46 AM   #6
A fuel pressure regulator is what works best. But,I like Quadrajet carbs the best.
Old 09-20-2011, 10:03 AM   #7
Burt4x4
Burt4x4's Avatar
Another vote for a clean well built 750CFM Q-Jet. Edelbrock use to make a Q-jet. I ran the 1901 Edelbrock Q-Jet for 10yrs off and on road.
One cool trick I used to help with the bumpy offroad slosh or splashing of fuel was to add a 3" peice of fuel line to the bowl vent tube at the top of the carb. Basically extending the vent tube another 3" keeps fuel from spitting out into the primarys wile offroad
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 09-21-2011, 03:30 AM   #8
Rifter_Chevy
i swapped out my stock q jet for a edelbrock 650 AVS thunder off road carb and the edelbrock will handle angles better than the q jet no question about it. Also boosted power switching to the edelbrock.
I have no experiance with the standard NON-off road edelbrocks.
1984 3/4 Ton Reg cab Longbox 4x4, Carbed 350/Turbo 400 Trans/205 T-Case
Rifter_Chevy is offline   Reply With Quote
Old 09-23-2011, 11:10 PM   #9
Brewski*
Brewski*'s Avatar
I am running the Holley Off Road Avenger. It works great.
Brewski* is offline   Reply With Quote
Old 09-24-2011, 07:28 AM   #10
OLDCHEV4X4
OLDCHEV4X4's Avatar
I run a quadrajet with the bowl vent extension like Burt4x4.
And a pressure regulator like Special K.
And I set the float level a little low.
I removed the stock fuel filter and run a inline filter.
Adjusted the secondary's to open early.
Eliminate the choke.
Made a phenolic carb spacer to help insulate from heat.
All this ads up to a good runnin carb that can do hill climb's, steep down hills, handle the bumps, and blast down the smooth strait away's in all 3 gears.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 09-25-2011, 12:05 AM   #11
rayfinseats
How much play in the primary throttle shaft is acceptable? (QJET) Mine has a little but it doesn't seem bad to me. They wouldn't have this problem if people would put the return spring facing forward and not rearward.
Old 09-25-2011, 08:48 AM   #12
OLDCHEV4X4
OLDCHEV4X4's Avatar
I've run them with alot of slop, and they dont run as smooth as the tight ones, but they still run good enough to use. If I had to guess a measurement I'd say less than a 1/16 at the base plate.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 09-26-2011, 10:16 AM   #13
rayfinseats
This is less than that. Prob a few hundredths inch.
Old 09-26-2011, 10:30 AM   #14
OLDCHEV4X4
OLDCHEV4X4's Avatar
.100 = One hundred's of a inch
.010 = Ten thousands of a inch or one tenths of a inch
.001= one thousand's of a inch
A few hundreds is .300 , thats alot.
I think you mean a few thousands?
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 09-26-2011, 09:20 PM   #15
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Quadrajet! I love them! My most recent one was leaking a little on my 454 so I swapped it out for a edelbrock witch I thought was good but it started leaking around the accelerator pump an ran even worse than the Q jet so I rebuilt the Q jet and it runs like a dream now, its the 800 cfm version too.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 10-04-2011, 10:54 PM   #16
rayfinseats
I had a '80 Qjet and I just picked up a '68 Qjet. I think it has a little less slop. I'm itchin to rebuild it and throw my performer manifold on. Now it has the edelbr carb with an adapter and cast intake. I think thats why its underpowered is the square to spreadbore adapter.
Old 10-05-2011, 12:24 AM   #17
Your41Plague12
Your41Plague12's Avatar
NO.
.100 = one tenth of an inch.
.010 = one hundredth of an inch.
.001 = one thousandth of an inch.
1/100 = .01. A few of them is about .03. Not a lot.
OP, I'd go with a properly set up Quadrajet. They're relatively hard to beat.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
