Old 09-30-2011, 11:14 AM   #1
coyote72
coyote72's Avatar
Elevation changes/jetting on the trail?
I was curious what you guys out there do when wheeling up into higher elevations with a carb. I just moved to Colorado and am anxious to go wheeling. The elevation at home is about 6000', and some of the trails out there have peaks in the 11,000' + range. I am running a q-jet, so changing jets and metering rods is not the easiest thing to do on the trail, but will be done if needed. What are some of the things you guys do?
72 K5 4x4 350
70 Nova 454 5spd 4-link
coyote72 is offline   Reply With Quote
Old 09-30-2011, 01:22 PM   #2
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: Elevation changes/jetting on the trail?
I dealt with that for years. No matter what you do carburetors just don’t work well at high altitude. I gave up and went to fuel injection. Problem solved.
DirtyLarry is offline   Reply With Quote
Old 09-30-2011, 02:16 PM   #3
72freak
Rottenwood Garage Member
72freak's Avatar
Yep!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 10-01-2011, 02:39 AM   #4
'63GENIII
'63GENIII's Avatar
FI or diesel. Carbs are a pain for elevation changes. I ran up to Street Vibrations one year on the bike and had to change jets 4 times in 6 hours. Im all about the FI these days!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-01-2011, 08:16 PM   #5
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Run it on propane.
--Josh
Old 10-02-2011, 11:03 AM   #6
Zoomad75
K5Camper
Zoomad75's Avatar
While I agree, FI is the way to eliminate the problem, I've had decent luck with my q-jet. However I don't fool around with changing rods/jets on trail. From my home altitude of 4800ft to 13,000ft all I've done is give a little bump in timing and couple hundered rpm increase in idle speed and it putts right along.
The thing is crawling along on the trail I'm not running WOT or even 1/2 throttle so making major changes in the rods/jets really wouldn't have an impact. The minor bump in timing is really more an improvement that I can feel. I just snug the dist clamp enough to hold it, but still allow a little movement if you bump it with the palm of your hand.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 10-03-2011, 12:00 AM   #7
coyote72
coyote72's Avatar
Thanks for the feedback. I am still in the process of dialing it in from sea level. I think I may try a lighter power piston spring. I see you are from CO as well, we will have to get together for a wheeling trip!
72 K5 4x4 350
Old 10-03-2011, 11:29 PM   #8
Zoomad75
K5Camper
Zoomad75's Avatar
Once you get it set up for your home altitude, climbing up from there shouldn't be too much of a problem. Remember we got less air up here, so have to go leaner on the mixture. It will need more timing than at sea level. Get it set so it's running good at home and then give it that little bump in timing when you are up in the mountains if you need it.
Not sure the next run is, but probably it will be in the snow when we get some. DirtyLarry and I are south of you in Pueblo, but that's not all that far and there's some good trails not too far from all of us.
Rob Z.
